Add a visual model to the rope in isaacsim
isaac sim
5.1.0
Operating System
Ubuntu 24.04
Detailed Description
In isaacsim, the rope is composed of multiple capsule bodies connected by ball hinges. If I want to give the rope as a whole a visual model like the one shown in the following figure instead of giving individual capsule bodies to make the rope look more realistic, can this be achieved?
Hi, this is doable. Your rope is a rigid-body chain (capsules + spherical/ball joints), so the visual just needs to follow those bodies. A few options(least to most effort):
  1. Per-segment meshes parented to the capsules (simplest, no scripting).
    Hide the capsule debug visuals (select each capsule and set it invisible, or set its purpose to guide, keeping only the collision), then parent a nicely modeled short tube/cylinder segment (with your material and UVs) under each capsule’s rigid-body Xform. The segments inherit each body’s transform automatically — no per-frame code — so the rope renders as your mesh. Make the segments slightly longer than the capsule spacing so they overlap and hide the seams at the joints. With a reasonable segment count this looks good and is the quickest win.
  2. A single continuous tube via UsdGeom.BasisCurves (smoothest “rope” look).
    Create one cubic BasisCurves (e.g. bspline) whose control points are the capsule centers, give it a widths value, and the RTX renderer draws it as a smooth round tube — one continuous surface with no seams. Update the curve points from the live body positions each physics step:
    • read each capsule’s world position (e.g. isaacsim.core.experimental.prims.RigidPrim), and
    • write them into the curve’s points attribute inside a per-step callback:
      SimulationManager.register_callback(update_fn, event=SimulationEvent.PHYSICS_POST_STEP).
      It’s a very small update (N points/step) and gives the cleanest rope appearance with minimal geometry. Assign a material to the curve for color/roughness.
  3. A skinned tube mesh (UsdSkel) — the fullest “unified model”.
    Author a tube Mesh once, bind it to a UsdSkel skeleton with one joint per capsule plus skin weights, and drive the skeleton joints from the capsule transforms each physics step (same callback as above). More setup (skeleton + weights), but you get a proper solid, deforming mesh with real UVs/materials — best for close-ups.
For most cases I’d start with option 1 (fast, no code) and move to option 2 if you want a truly seamless rope. Option 3 only if you need a textured solid mesh.
One aside: if you don’t specifically need the capsule-chain physics, PhysX’s particle-based rope (or a deformable) generates a smooth continuous surface natively — but that changes the simulation model, so only consider it if the rope dynamics can change.
Ok, thank you. But I have tried the particle, which seems to be used for fluid simulation. As for the volume flexible body, I adjusted the resolution of the mesh, but for slender objects, the mesh simulation effect is not very good. There will be a situation where the mesh is missing, and when there are many flexible bodies, the simulation will be distorted
Hi, what you’re seeing with the volumetric deformable is expected, and it points to why a rope is a tricky fit for FEM. A volumetric soft body assumes roughly comparable dimensions in all three axes; a rope is the opposite (extreme aspect ratio), and that’s the root of all the symptoms:
  • “Mesh not good for slender objects” / “mesh missing”: raising the render resolution won’t help — what matters is the simulation (collision) tet mesh. The auto-tetrahedralizer struggles to fit well-conditioned tets across a thin cross-section and produces sliver (near-degenerate) tets, which either get culled or blow up numerically — that’s the “missing mesh.” Fixes: (1) make sure at least 2–3 tets span the diameter — one tet across a cross-section has no bending DOF; (2) prefer a voxel/hexahedral sim mesh over a conforming one and raise the voxel resolution so the thin dimension actually gets voxels — it trades element count for much better conditioning; (3) if slivers persist, author a clean swept-tube tet mesh externally and import it as the collision mesh. Also make sure every render vertex is fully enclosed by the collision mesh (inflate it slightly) — render verts poking outside the sim mesh don’t get skinned, which also shows up as holes.
  • “Many bodies → distortion”: this is a solver/GPU budget problem. Raise solver_position_iteration_count (deformables want more than rigids — try 16–32), add substeps / a smaller physics dt, add velocity/vertex damping, and soften the material (lower Young’s modulus) so it isn’t stiff-and-explosive. Check self-collision (enable it but set a sensible filter distance). And importantly — distortion that only appears once you add many bodies is usually a GPU buffer overflow: bump the PhysX GPU capacity params (gpu_max_soft_body_contacts, collision-stack / found-pairs / temp-buffer capacities). When contacts exceed the buffer they’re silently dropped and the sim goes visibly wrong exactly when you scale up. Watch the console for GPU-buffer-overflow warnings to confirm.
That said — even fully tuned, FEM on a rope stays fragile and expensive, because you’re using a volumetric solver for a fundamentally 1D problem. You already have the right physics model: the capsule + ball-hinge chain. It’s stable, cheap, and scales to many ropes without any of the above. The only thing it was missing is a nice visual — and that’s a rendering problem, not a physics one. So keep your chain and drive a visual-only mesh from the capsule transforms.
For a rope, UsdGeom.BasisCurves is the sweet spot — one lightweight prim, seamless tube, updated each physics step from the simulated capsule centers:
   from pxr import UsdGeom, Gf, Vt
   import omni.usd
   capsule_paths = [f"/World/Rope/segment_{i}/capsule" for i in range(num_segments)]
   curve = UsdGeom.BasisCurves.Define(stage, "/World/Rope/VisualTube")
   curve.CreateTypeAttr("cubic")
   curve.CreateBasisAttr("bspline")
   curve.CreateWrapAttr("nonperiodic")
   curve.CreateCurveVertexCountsAttr([len(capsule_paths)])
   curve.CreateWidthsAttr([rope_diameter] * len(capsule_paths))
   curve.SetWidthsInterpolation("vertex")
   # bind a material to the curve here for the realistic look
   def update_visual_tube(dt):
       xform_cache = UsdGeom.XformCache()
       pts = [Gf.Vec3f(xform_cache.GetLocalToWorldTransform(
                  stage.GetPrimAtPath(p)).ExtractTranslation())
              for p in capsule_paths]
       curve.GetPointsAttr().Set(Vt.Vec3fArray(pts))
Register update_visual_tube on the physics step and hide the capsule render meshes (keep their colliders). The curve reads the simulated capsule centers every frame, so the visual follows the physics with zero effect on it. Use bspline so the tube stays smooth through the joints, and bind a material with a tiling normal/albedo for the braided look. If you need actual textured geometry (for a specific renderer or export), option 3 — a skinned UsdSkel tube with one joint per capsule — uses the same driving idea with more setup.
Finally, one correction on particles: they aren’t only for fluids. The same PBD particle system does cloth and inflatables, and a connected 1D chain of particles with distance + bending constraints is effectively a rope — that’s the intended primitive for slender flexible objects if you want stretch/squash that a rigid chain can’t give, and it sidesteps tetrahedralization entirely. So if the rigid-chain-plus-visual route isn’t flexible enough for your use case, PBD particle rope is the better middle ground than volumetric FEM.
Thank you for your reply. Your use of basiscurves for the visual skinning of flexible ropes should be the most effective approach at isaacsim at present. By the way, the ball joint not supporting the drive will cause the rope to lack damping and stiffness. It is recommended to use the D6 joint
Hi, glad the BasisCurves skinning approach worked out for you! That’s a great tip about using D6 joints instead of ball joints to get proper drive support (damping and stiffness) on the rope — thanks for sharing that with the community. If you run into further questions, feel free to open new topics! I am closing this one.
