Wire and Rope's simulation in Isaac Sim4.5 or 4.2
I would like to know that you have any tutorials related to Wire and Rope’s simulation in Isaac Sim4.5 or 4.2.
I have already known that there are some tutorials about Physics Examples below:
In addition, I have already checked that there are many tutorials about Physics Examples in Windows->Examples->Physics Examples.
Could you please give us some comments for the above?
thanks
Hi @A_Y,
Unfortunately, we currently don’t have good tutorials available, but I have create a example script that might be useful for you. It is posted here: How to attach a cable to a winch mechanism? - #4 by michalin Let me know if this helps you.
Michael
To @michalin -san,
Thank you for sharing this information with us and creating this scripts here. I really appreciate it!!!
In addition, we have a question below:
When we would like not to scroll the cable but cut the one, how we do it with the script you made?
Should we cut the Joint things?
Could you please share some scripts as an example with us?
Best regards
I am glad that was helpful. If you want to cut the rope, I would recommend disabling the joint corresponding to the segment you want to cut. Here is an example (I have also improved the script a bit).
#!/usr/bin/env python3
# Copyright (c) 2022-2024, NVIDIA CORPORATION. All rights reserved.
# NVIDIA CORPORATION and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA CORPORATION is strictly prohibited.
This script demonstrates how to create a cable/rope mechanism using individual prims.
The rope is made of rigid body capsules connected with spherical joints.
from isaacsim import SimulationApp
# Launch Isaac Sim
simulation_app = SimulationApp({"headless": False})
import time
from pxr import Usd, UsdGeom, UsdPhysics, Gf, Sdf, PhysxSchema, UsdShade, UsdLux
from omni.physx.scripts import physicsUtils
from omni.timeline import get_timeline_interface
from isaacsim.core.api import World
from isaacsim.core.utils.prims import get_prim_at_path
# Set Light stage to Grey Studio
stage = simulation_app.context.get_stage()
light_stage = stage.GetPrimAtPath("/Environment")
if not light_stage:
    light_stage = stage.DefinePrim("/Environment", "Xform")
# Create Grey Studio lighting environment
dome_light = UsdLux.DomeLight.Define(stage, "/Environment/GreyStudio")
dome_light.CreateIntensityAttr().Set(1000.0)
class SphericalJoint:
    def __init__(self, stage, joint_path, body0_path, body1_path, local_pos0, local_pos1,
                 damping=0.0, stiffness=0.0, enable_drives=True):
        self.stage = stage
        self.joint_path = joint_path
        self.body0_path = body0_path
        self.body1_path = body1_path
        self.local_pos0 = local_pos0
        self.local_pos1 = local_pos1
        self.damping = damping
        self.stiffness = stiffness
        self.enable_drives = enable_drives
        self.joint = None
        self._create_joint()
    def _create_joint(self):
        # Create a D6 joint
        self.joint = UsdPhysics.Joint.Define(self.stage, self.joint_path)
        joint_prim = self.joint.GetPrim()
        # Lock all translational degrees of freedom
        for axis in ["transX", "transY", "transZ", "rotX"]:
            limitAPI = UsdPhysics.LimitAPI.Apply(joint_prim, axis)
            limitAPI.CreateLowAttr(1.0)
            limitAPI.CreateHighAttr(-1.0)
        # Set the bodies to connect
        self.joint.GetBody0Rel().SetTargets([self.body0_path])
        self.joint.GetBody1Rel().SetTargets([self.body1_path])
        # Set local positions
        self.joint.CreateLocalPos0Attr().Set(self.local_pos0)
        self.joint.CreateLocalPos1Attr().Set(self.local_pos1)
        # Set local rotations (identity quaternions)
        self.joint.CreateLocalRot0Attr().Set(Gf.Quatf(1.0))
        self.joint.CreateLocalRot1Attr().Set(Gf.Quatf(1.0))
        # Configure joint drives for Y and Z rotation if enabled
        if self.enable_drives:
            for axis in ["rotY", "rotZ"]:
                limitAPI.CreateLowAttr(-1)
                limitAPI.CreateHighAttr(1)
                driveAPI = UsdPhysics.DriveAPI.Apply(joint_prim, axis)
                driveAPI.CreateTypeAttr("force")
                driveAPI.CreateDampingAttr(self.damping)
                driveAPI.CreateStiffnessAttr(self.stiffness)
    def get_joint(self):
        return self.joint
class RopeCreator:
    def __init__(self, stage, default_prim_path, physics_material_path, pivot_point=None,
                 link_half_length=0.1, rope_length=2.0, num_ropes=1, rope_spacing=0.1,
                 rope_color=None, rope_damping=2.0, rope_stiffness=0.0, contact_offset=0.01,
                 enable_joint_drives=True, rope_segment_mass=0.00005):
        self.stage = stage
        self.default_prim_path = default_prim_path
        self.physics_material_path = physics_material_path
        self.pivot_point = pivot_point if pivot_point is not None else Gf.Vec3f(0.0, 0.0, 1.0)
        # Configure rope parameters
        self.link_half_length = link_half_length
        self.link_radius = 0.5 * self.link_half_length
        self.rope_length = rope_length
        self.num_ropes = num_ropes
        self.rope_spacing = rope_spacing
        self.rope_color = rope_color if rope_color is not None else Gf.Vec3f(0.2, 0.6, 0.8)  # Blue-ish color
        self.rope_damping = rope_damping
        self.rope_stiffness = rope_stiffness
        self.contact_offset = contact_offset
        self.enable_joint_drives = enable_joint_drives
        self.rope_segment_mass = rope_segment_mass
        # Store segment prims and joints for the rope
        self.segments = []  # List of segment prims
        self.joints = []    # List of joint prims
    def create_capsule(self, path, position):
        capsule_geom = UsdGeom.Capsule.Define(self.stage, path)
        capsule_geom.CreateHeightAttr(self.link_half_length)
        capsule_geom.CreateRadiusAttr(self.link_radius)
        capsule_geom.CreateAxisAttr("X")
        capsule_geom.CreateDisplayColorAttr().Set([self.rope_color])
        # Set position
        capsule_geom.AddTranslateOp().Set(position)
        UsdPhysics.CollisionAPI.Apply(capsule_geom.GetPrim())
        UsdPhysics.RigidBodyAPI.Apply(capsule_geom.GetPrim())
        mass_api = UsdPhysics.MassAPI.Apply(capsule_geom.GetPrim())
        mass_api.CreateMassAttr().Set(self.rope_segment_mass)
        physx_collision_api = PhysxSchema.PhysxCollisionAPI.Apply(capsule_geom.GetPrim())
        physx_collision_api.CreateRestOffsetAttr().Set(0.0)
        physx_collision_api.CreateContactOffsetAttr().Set(self.contact_offset)
        physicsUtils.add_physics_material_to_prim(self.stage, capsule_geom.GetPrim(), self.physics_material_path)
        return capsule_geom
    def create_joint(self, joint_path, body0_path, body1_path, local_pos0, local_pos1):
        # Create a spherical joint using the new abstraction
        spherical_joint = SphericalJoint(
            self.stage,
            joint_path,
            body0_path,
            body1_path,
            local_pos0,
            local_pos1,
            damping=self.rope_damping,
            stiffness=self.rope_stiffness,
            enable_drives=self.enable_joint_drives
        return spherical_joint.get_joint()
    def create_ropes(self):
        # Calculate spacing and dimensions
        link_length = 2.0 * self.link_half_length
        num_links = int(self.rope_length / link_length)
        y_start = -(self.num_ropes // 2) * self.rope_spacing
        for rope_ind in range(self.num_ropes):
            scope_path = self.default_prim_path.AppendChild(f"Rope{rope_ind}")
            UsdGeom.Scope.Define(self.stage, scope_path)
            y = y_start + rope_ind * self.rope_spacing
            z = self.pivot_point[2]  # Use pivot point's z coordinate
            # Create all capsule links
            for link_ind in range(num_links):
                x = self.pivot_point[0] + link_ind * link_length  # Start from pivot point's x coordinate
                position = Gf.Vec3f(x, self.pivot_point[1] + y, z)  # Add y offset for multiple ropes
                capsule_path = scope_path.AppendChild(f"capsule_{link_ind}")
                capsule_geom = self.create_capsule(capsule_path, position)
                self.segments.append(capsule_geom.GetPrim())
            # Create joints between consecutive capsules
            joint_x = self.link_half_length
            for link_ind in range(num_links - 1):
                joint_path = scope_path.AppendChild(f"joint_{link_ind}")
                body0_path = self.segments[link_ind].GetPath()
                body1_path = self.segments[link_ind + 1].GetPath()
                local_pos0 = Gf.Vec3f(joint_x, 0, 0)
                local_pos1 = Gf.Vec3f(-joint_x, 0, 0)
                joint = self.create_joint(joint_path, body0_path, body1_path, local_pos0, local_pos1)
                self.joints.append(joint)
    def get_segments(self):
        """Get all segment prims for the rope"""
        return self.segments
    def get_joints(self):
        """Get all joint prims for the rope"""
        return self.joints
    def get_first_segment(self):
        """Get the first segment prim for the rope"""
        return self.segments[0] if self.segments else None
    def get_last_segment(self):
        """Get the last segment prim for the rope"""
        return self.segments[-1] if self.segments else None
def create_cylinder(stage, parent_path, name, radius=0.5, height=1.0, position=None, rotation_y=90.0):
    Create a cylinder with physics properties and a revolute joint.
    Args:
        stage: The USD stage
        parent_path: Path to the parent prim
        name: Name for the cylinder prim
        radius: Radius of the cylinder in meters
        height: Height of the cylinder in meters
        position: Position of the cylinder (Gf.Vec3f), defaults to (0, 0, 2)
        rotation_y: Rotation around Y axis in degrees, defaults to 90
    Returns:
        tuple: (cylinder_path, joint_path) - Paths to the created cylinder and joint
    if position is None:
        position = Gf.Vec3f(0.0, 0.0, 1.0)
    # Create cylinder
    cylinder_path = parent_path.AppendChild(name)
    cylinder_geom = UsdGeom.Cylinder.Define(stage, cylinder_path)
    cylinder_geom.CreateRadiusAttr().Set(radius)
    cylinder_geom.CreateHeightAttr().Set(height)
    cylinder_geom.CreateAxisAttr().Set(UsdGeom.Tokens.z)
    # Set position and rotation
    cylinder_geom.AddTranslateOp().Set(position)
    cylinder_geom.AddRotateYOp().Set(rotation_y)
    # Add physics properties
    UsdPhysics.CollisionAPI.Apply(cylinder_geom.GetPrim())
    UsdPhysics.RigidBodyAPI.Apply(cylinder_geom.GetPrim())
    # Create revolute joint
    joint_path = parent_path.AppendChild(f"{name}_joint")
    joint = UsdPhysics.RevoluteJoint.Define(stage, joint_path)
    # Set joint bodies
    joint.CreateBody0Rel().SetTargets([parent_path])  # World
    joint.CreateBody1Rel().SetTargets([cylinder_path])  # Cylinder
    # Set joint axis
    joint.CreateAxisAttr().Set("Y")
    joint.CreateLocalPos0Attr().Set(position)
    joint.CreateLocalPos1Attr().Set(Gf.Vec3f(0.0, 0.0, 0.0))
    joint.CreateLocalRot0Attr().Set(Gf.Quatf(1.0, 0.0, 0.0, 0.0))
    joint.CreateLocalRot1Attr().Set(Gf.Quatf(0.707, 0.707, 0.0, 0.0))
    # Add joint drive
    drive = UsdPhysics.DriveAPI.Apply(joint.GetPrim(), "angular")
    drive.CreateTypeAttr().Set("force")
    drive.CreateTargetVelocityAttr().Set(1.0)  # Rotate at 1 rad/s
    drive.CreateDampingAttr().Set(1.0)
    drive.CreateStiffnessAttr().Set(10.0)
    return cylinder_path, joint_path, drive
# Create a world
my_world = World(stage_units_in_meters=1.0)
# Add default ground plane
my_world.scene.add_default_ground_plane()
# Get the stage
# Enable Physics
scene = UsdPhysics.Scene.Define(stage, "/physicsScene")
scene.CreateGravityDirectionAttr().Set(Gf.Vec3f(0.0, 0.0, -1.0))
scene.CreateGravityMagnitudeAttr().Set(9.81)
# Create default prim and physics material
default_prim_path = Sdf.Path("/World")
UsdGeom.Xform.Define(stage, default_prim_path)
stage.SetDefaultPrim(stage.GetPrimAtPath(default_prim_path))
# Create the cylinder using the helper function
cylinder_radius = 0.3
cylinder_height = 2.0
cylinder_path, joint_path, drive = create_cylinder(stage, default_prim_path, "cylinder", radius=cylinder_radius, height=cylinder_height)
# Create the rope creator and generate ropes
physics_material_path = default_prim_path.AppendChild("PhysicsMaterial")
UsdShade.Material.Define(stage, physics_material_path)
material = UsdPhysics.MaterialAPI.Apply(stage.GetPrimAtPath(physics_material_path))
material.CreateStaticFrictionAttr().Set(0.5)
material.CreateDynamicFrictionAttr().Set(0.5)
material.CreateRestitutionAttr().Set(0)
rope_creator = RopeCreator(stage,
                           default_prim_path,
                           pivot_point=Gf.Vec3f(0.5, 0.0, 1.0),
                           rope_length=4.0,
                           num_ropes=1,
                           rope_spacing=0.1,
                           rope_damping=10e6,
                           rope_stiffness=0,
                           rope_segment_mass=10e-6,
                           enable_joint_drives=False)  # Set to False to disable joint drives
rope_creator.create_ropes()
# Create a spherical joint between the cylinder perimeter and the first capsule of the rope
# Get the first capsule path
first_capsule_path = "/World/Rope0/capsule_0"
# Create the spherical joint
attachment_joint_path = default_prim_path.AppendChild("cylinder_rope_attachment")
attachment_joint = UsdPhysics.SphericalJoint.Define(stage, attachment_joint_path)
# Connect the cylinder and first capsule
attachment_joint.GetBody0Rel().SetTargets([cylinder_path])
attachment_joint.GetBody1Rel().SetTargets([first_capsule_path])
# Set local positions - attach at cylinder perimeter (radius 0.5) and capsule center
attachment_joint.CreateLocalPos0Attr().Set(Gf.Vec3f(cylinder_radius, 0.0, 0.0))  # At cylinder perimeter
attachment_joint.CreateLocalPos1Attr().Set(Gf.Vec3f(-0.1, 0.0, 0.0))  # At capsule edge
attachment_joint.CreateLocalRot0Attr().Set(Gf.Quatf(1.0, 0.0, 0.0, 0.0))
attachment_joint.CreateLocalRot1Attr().Set(Gf.Quatf(1.0, 0.0, 0.0, 0.0))
# Initial setup for the simulation
timeline = get_timeline_interface()
# Start the simulation
timeline.play()
# Wait for the simulation to start
while not timeline.is_playing():
    simulation_app.update()
    time.sleep(0.01)
# Keep the simulation running
print("Simulation started. Press Ctrl+C to exit")
position = 0.0
time_iter_to_cut = 5*100
loop_counter = 0
try:
    while timeline.is_playing():
        loop_counter += 1
        # Continuously increment the joint drive position
        position += 1.  # Increment by 0.01 radians per frame
        drive.CreateTargetPositionAttr().Set(position)
        if loop_counter == time_iter_to_cut:
            print("Cutting the rope")
            rope_creator.get_joints()[5].GetPrim().GetAttribute('physics:jointEnabled').Set(False)
        time.sleep(0.01)
except KeyboardInterrupt:
    print("Simulation stopped by user")
finally:
    # Stop the simulation
    timeline.stop()
    simulation_app.close()
