I take the link as reference to add SD support on our carrier board. And add the node as below into the dts file:
sdmmc3: sdmmc3@3440000 {
mmc-ocr-mask = <0x0>;
cd-inverted;
cd-gpios = <&tegra_aon_gpio TEGRA194_AON_GPIO(CC, 4) 0>;
nvidia,cd-wakeup-capable;
mmc-ocr-mask = <0>;
cd-inverted;
vmmc-supply = <&p3668_vdd_sdmmc3_sw>;
status = "okay";
But when comple the device tree, it says:
ERROR (duplicate_property_names): Duplicate property name mmc-ocr-mask in /sdmmc3@3400000
ERROR (duplicate_property_names): Duplicate property name cd-inverted in /sdmmc3@3400000
But, the official ‘sdhci_sd’ node has similar configuration:
sdhci_sd: sdhci@3400000 {
cd-inverted;
cd-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 7) 0>;
mmc-ocr-mask = <0>;
cd-inverted;
vmmc-supply = <&p3668_vdd_sdmmc1_sw>;
status = "okay";
But it won’t throw errors, why?
How do you build your dtb here?
I bypassed the kernel build and run as below:
make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j2 dtbs
So your kernel build (dtb) will by default fail?
If do no changes to the kernel and device tree and run
There will be no errors.
The errors occurred after adding the SDMMC3 to the device tree, but I added “dtbs” after ‘-j2’ switch intend to reduce the compiling time.
- Will the bypass of the kernel build caused the problem? That is, I shouldn’t add “dtbs”?
- Or there some errors in my device tree modifications? Note: I also included “-pinmux.dtsi”, “-padvoltage-default.dtsi” and “-gpio-default.dtst” in the “xxxx-all-p3509-0000.dts” file.
What are you exactly adding? I mean I don’t understand what is " The errors occurred after adding the SDMMC3 ". What do you mean adding “sdmmc3”? Why not you just modify the existing nodes?
My module is a production version of NX module. And we designed a SD Card interface routed to SDMMC3. So, we add the above node in the 'tegra194-p3668-common.dtsi‘. What’s the correct way to add it?
Try to add just “sdmmc3@3440000” but not “sdmmc3: sdmmc3@3440000”
Also, if that duplicated error still happened, then just fix this manually. Really no need spend too much time on this minor error.
If the GPIO used for CD pin is not a wake-up-capable pin (the ‘Wake’ column is empty in the excel pinmux tool), is the ‘nvidia,cd-wakeup-capable’ still needed or not? That is, if the ‘wake-up-capable’ property in the device tree is related with the hardware wake up function?
