• Hardware Platform (Jetson / GPU) [GeForce RTX 3070 Ti]
• DeepStream Version version 6.0.0
• TensorRT Version TensorRT-8.2.1.8
• NVIDIA GPU Driver Version (valid for GPU only) CUDA Version: 11.5
2022-09-07 16:18:20,968 INFO gstname=audio/x-raw
Added tracker node (tracker) print format error
!![Exception] [NvMOTContext::processFrame()] motFrame->bufferList[i]->colorFormat != m_Config.perTransformBatchConfig[i].colorFormat
An exception occurred. [NvMOTContext::processFrame()] motFrame->bufferList[i]->colorFormat != m_Config.perTransformBatchConfig[i].colorFormat
I tried to add nvvideoconvert in front of the nvtracker plugin, but the same error was reported
# Use convertor to convert
nvvidconv4 = Gst.ElementFactory.make(“nvvideoconvert”, “nvvidconv4”)
if not nvvidconv4:
logger.error(" Unable to create nvvidconv4 \n")
# Create a caps filter
filter4 = Gst.ElementFactory.make(“capsfilter”, “filter4”)
if not filter4:
logger.error(" Unable to get the caps filter4 \n")
filter4.set_property(“caps”, Gst.Caps.from_string(“video/x-raw(memory:NVMM), format=NV12”))
nvstreammux2.link(nvvidconv4)
nvvidconv4.link(filter4)
filter4.link(tracker)
