I’m trying to simulate waves in a domain with an obstacle. My model works fine without adding the obstacle constraint, however, when I’m trying to add this “c” (speed of soundwave) map for the speed of sound as a constraint in my simulation,
I exported the values of x, y, and c_output to an NPZ file from my external script, and I’m trying to import them into my modulus code as such:
# Read in the C (speed of sound) map generated using finite difference simulator
obstacle_filename = to_absolute_path(f"FDM_data/obstacle.npz")
c_map = np.load(obstacle_filename)
t = np.array(c_map["t_input"]).flatten()[:, None].astype(np.float32)
y = np.array(c_map["y_input"]).flatten()[:, None].astype(np.float32)
x = np.array(c_map["x_input"]).flatten()[:, None].astype(np.float32)
c_obstacle = np.array(c_map["c_output"]).astype(np.float32)
mesh_x, mesh_y, mesh_t = np.meshgrid(
x,y,t, indexing="ij"
wave_speed_invar = {}
wave_speed_invar["x"] = np.expand_dims(mesh_x.flatten(), axis=-1)
wave_speed_invar["y"] = np.expand_dims(mesh_y.flatten(), axis=-1)
wave_speed_invar["t"] = np.expand_dims(mesh_t.flatten(), axis=-1)
wave_speed_outvar = {}
wave_speed_outvar["c"] = c_obstacle
# add speed of sound constraint
c_speed= PointwiseConstraint.from_numpy(
nodes=nodes, invar=wave_speed_invar, outvar=wave_speed_outvar, batch_size=1024
domain.add_constraint(c_speed, "C_Speed")
I receive this error:
Error executing job with overrides: []
File "wave_2d_inhomo_RVE.py", line 454, in run
slv.solve()
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\modulus-22.9-py3.8.egg\modulus\solver\solver.py", line 159, in solve
self._train_loop(sigterm_handler)
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\modulus-22.9-py3.8.egg\modulus\trainer.py", line 519, in _train_loop
self.load_data(static=True)
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\modulus-22.9-py3.8.egg\modulus\solver\solver.py", line 61, in load_data
self.domain.load_data(static)
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\modulus-22.9-py3.8.egg\modulus\domain\domain.py", line 122, in load_data
constraint.load_data_static()
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\modulus-22.9-py3.8.egg\modulus\domain\constraint\continuous.py", line 94, in load_data_static
self.load_data()
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\modulus-22.9-py3.8.egg\modulus\domain\constraint\continuous.py", line 81, in load_data
invar, true_outvar, lambda_weighting = next(self.dataloader)
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\modulus-22.9-py3.8.egg\modulus\domain\constraint\constraint.py", line 238, in __iter__
for batch in dataloader:
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\torch\utils\data\dataloader.py", line 628, in __next__
data = self._next_data()
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\torch\utils\data\dataloader.py", line 671, in _next_data
data = self._dataset_fetcher.fetch(index) # may raise StopIteration
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\torch\utils\data\_utils\fetch.py", line 60, in fetch
data = self.dataset[possibly_batched_index]
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\modulus-22.9-py3.8.egg\modulus\dataset\continuous.py", line 39, in __getitem__
outvar = _DictDatasetMixin._idx_var(self.outvar, idx)
File "C:\ProgramData\Anaconda3\envs\modulus_env\lib\site-packages\modulus-22.9-py3.8.egg\modulus\dataset\dataset.py", line 117, in _idx_var
idx_var[key] = value[idx]
IndexError: index 553925 is out of bounds for dimension 0 with size 100
For clarification, x is a dimension from 0 to 5 with 100 steps and y, t are the same. Also, the values of speed don’t change over time so the values I’m trying to import are constant throughout the time steps.
How can I proceed with training my model while having these constant values of c (speed of soundwave) in my domain? Please advise.
