It comes from factory with no CUDA installed, no cuDNN. It has JetPack 4.3.
Using this configuration, is there any way to get benefits from the GPU? As far as I know, it is useless. It is just an ARM processor with no use of GPU. Am I wrong?
Hello @flavio.mello ,
Is there a reason you cannot install software on the device?
If not, you have a couple of options, use the sdk manager to install cuda and other sdk components or use apt. For both you can do it via ssh.
The easier option with gui is sdkmanager.
You need a pc with the sdk manager installed. Preferably Ubuntu 18.X or 16.X otherwise you cannot use the normal sdkmanager to install JP 4.X versions, and you will need to use docker, like [here].(Docker Images :: NVIDIA SDK Manager Documentation)
On this screen select the target JP version and the target hardware. In your case JP 4.3, you may need to open sdkmanager in console with “sdkmanager --archivedversions” if it doesn’t show up.
So, I was trying an alternative do SDK Manager because I had to have access to the mainboard. But I gave up and break the warranty seal of the Advantec box in order to access the USB maintainance slot and REC/RST buttons. Now I installed everything through SDK Manager.
The OpenGL 4.1.1 that is installed by SDK Manager will use GPU or it needs to be recompliled with CUDA access?
@flavio.mello
It should have it, I do know that OpenCV is not included with Cuda by default, but OpenGL should. Have a look at this example and see it it works. Or if you want somehting a bit more complex.
Also refering to opening the carrier, for the install using the sdk manager at least for the sdk components, that could be done via ssh, you don’t need to go into the recovery port. But if you want to completely reinstall jetpack, then it’s needed.
