Aerila cuBB end-to-end test cuphycontroller init fail
I am trying to run the cuBB E2E test in the 25-1-cuBB environment and have followed the steps to set up the related SDK and firmware on my GH200 server. However, when running cuphycontroller_scf show the log about DOCA error not support as below.
Based on the information shown, the DOCA version should not be the issue.
$ ofed_info -s
OFED-internal-24.04-0.6.6:
And my BF3 informatino is as below:
$ sudo mlxfwmanager -d 0002:01:00.0
Querying Mellanox devices firmware ...
Device #1:
  Device Type:      BlueField3
  Part Number:      900-9D3B6-00SV-A_Ax
  Description:      NVIDIA BlueField-3 B3220 P-Series FHHL DPU; 200GbE (default mode) / NDR200 IB; Dual-port QSFP112; PCIe Gen5.0 x16 with x16 PCIe extension option; 16 Arm cores; 32GB on-board DDR; integrated BMC; Crypto Disabled
  PSID:             MT_0000000965
  PCI Device Name:  0002:01:00.0
  Base MAC:         9c63c0b82600
  Versions:         Current        Available
     FW             32.41.1000     N/A
     PXE            3.7.0400       N/A
     UEFI           14.34.0012     N/A
     UEFI Virtio blk   22.4.0013      N/A
     UEFI Virtio net   21.4.0013      N/A
  Status:           No matching image found
The error log of cuphycontroller as below:
aerial@airan:/opt/nvidia/cuBB/build/cuPHY-CP/cuphycontroller/examples$ sudo -E ./cuphycontroller_scf F08_CG1
Started cuphycontroller on CPU core 70
Aerial metrics backend address: 127.0.0.1:8081
07:24:32.803751 CON phy_init 0 [CTL.SCF] Config file: /opt/nvidia/cuBB/cuPHY-CP/cuphycontroller/config/cuphycontroller_F08_CG1.yaml
07:24:32.804426 CON phy_init 0 [CTL.SCF] low_priority_core=23
07:24:32.804440 CON phy_init 0 [APP.CONFIG] Current TAI offset: 0s
07:24:32.804474 CON phy_init 0 [NVLOG.CPP] Using /opt/nvidia/cuBB/cuPHY/nvlog/config/nvlog_config.yaml for nvlog configuration
07:24:32.804709 CON phy_init 0 [NVLOG.CPP] Output log file path /tmp/phy.log
YAML invalid key: enable_l1_param_sanity_check Using default value of 0 to YAML_PARAM_ENABLE_L1_PARAM_SANITY_CHECK
YAML invalid key: bfw_beta_prescaler Using default value of 1 for YAML_PARAM_BFW_BETA_PRESCALER 2048
YAML invalid key: pusch_nMaxLdpcHetConfigs Using default value of 32 to PUSCH-N-MAX-LDPC-HET-CONFIGS
07:24:32.816210 CON phy_init 0 [CTL.YAML] cuphycontroller config. yaml does not have gpu_init_comms_via_cpu key; defaulting to 0.
07:24:32.816211 CON phy_init 0 [CTL.YAML] cuphycontroller config. yaml does not have cpu_init_comms key; defaulting to 0.
07:24:32.816367 CON phy_init 0 [CTL.YAML] cell_id 1 nic_index :0
07:24:32.816470 CON phy_init 0 [CTL.YAML] Num Slots: 8
07:24:32.816470 CON phy_init 0 [CTL.YAML] Enable UL cuPHY Graphs: 1
07:24:32.816470 CON phy_init 0 [CTL.YAML] Enable DL cuPHY Graphs: 1
07:24:32.816471 CON phy_init 0 [CTL.YAML] Accurate TX scheduling clock resolution (ns): 500
07:24:32.816471 CON phy_init 0 [CTL.YAML] DPDK core: 23
07:24:32.816471 CON phy_init 0 [CTL.YAML] Prometheus core: -1
07:24:32.816471 CON phy_init 0 [CTL.YAML] UL cores:
07:24:32.816472 CON phy_init 0 [CTL.YAML]       - 5
07:24:32.816472 CON phy_init 0 [CTL.YAML]       - 6
07:24:32.816472 CON phy_init 0 [CTL.YAML] DL cores:
07:24:32.816472 CON phy_init 0 [CTL.YAML]       - 11
07:24:32.816472 CON phy_init 0 [CTL.YAML]       - 12
07:24:32.816472 CON phy_init 0 [CTL.YAML]       - 13
07:24:32.816472 CON phy_init 0 [CTL.YAML] Debug worker: -1
07:24:32.816473 CON phy_init 0 [CTL.YAML] Data Lake core: -1
07:24:32.816473 CON phy_init 0 [CTL.YAML] SRS starting Section ID: 3072
07:24:32.816473 CON phy_init 0 [CTL.YAML] PRACH starting Section ID: 2048
07:24:32.816473 CON phy_init 0 [CTL.YAML] USE GREEN CONTEXTS: 0
07:24:32.816473 CON phy_init 0 [CTL.YAML] USE BATCHED MEMCPY: 1
07:24:32.816473 CON phy_init 0 [CTL.YAML] MPS SM PUSCH: 100
07:24:32.816473 CON phy_init 0 [CTL.YAML] MPS SM PUCCH: 2
07:24:32.816473 CON phy_init 0 [CTL.YAML] MPS SM PRACH: 2
07:24:32.816474 CON phy_init 0 [CTL.YAML] MPS SM UL ORDER: 20
07:24:32.816474 CON phy_init 0 [CTL.YAML] MPS SM PDSCH: 102
07:24:32.816474 CON phy_init 0 [CTL.YAML] MPS SM PDCCH: 10
07:24:32.816474 CON phy_init 0 [CTL.YAML] MPS SM PBCH: 2
07:24:32.816474 CON phy_init 0 [CTL.YAML] MPS SM GPU_COMMS: 16
07:24:32.816474 CON phy_init 0 [CTL.YAML] PDSCH fallback: 0
07:24:32.816474 CON phy_init 0 [CTL.YAML] Massive MIMO enable: 0
07:24:32.816474 CON phy_init 0 [CTL.YAML] mMIMO_enable feature 0
07:24:32.816474 CON phy_init 0 [CTL.YAML] Enable SRS : 0
07:24:32.816475 CON phy_init 0 [CTL.YAML] ul_order_timeout_gpu_log_enable: 0
07:24:32.816475 CON phy_init 0 [CTL.YAML] ue_mode: 0
07:24:32.816476 CON phy_init 0 [CTL.YAML] Aggr Obj Non-availability threshold: 5
07:24:32.816476 CON phy_init 0 [CTL.YAML] sendCPlane_timing_error_th_ns: 0
07:24:32.816476 CON phy_init 0 [CTL.YAML] pusch_aggr_per_ctx: 3
07:24:32.816476 CON phy_init 0 [CTL.YAML] prach_aggr_per_ctx: 2
07:24:32.816477 CON phy_init 0 [CTL.YAML] pucch_aggr_per_ctx: 4
07:24:32.816477 CON phy_init 0 [CTL.YAML] srs_aggr_per_ctx: 3
07:24:32.816477 CON phy_init 0 [CTL.YAML] max_harq_pools: 384
07:24:32.816477 CON phy_init 0 [CTL.YAML] ul_input_buffer_per_cell: 10
07:24:32.816477 CON phy_init 0 [CTL.YAML] ul_input_buffer_per_cell_srs: 6
07:24:32.816477 CON phy_init 0 [CTL.YAML] max_ru_unhealthy_ul_slots: 0
07:24:32.816477 CON phy_init 0 [CTL.YAML] srs_chest_algo_type: 0
07:24:32.816477 CON phy_init 0 [CTL.YAML] srs_chest_tol2_normalization_algo_type: 1
07:24:32.816477 CON phy_init 0 [CTL.YAML] srs_chest_tol2_constant_scaler: 32768
07:24:32.816478 CON phy_init 0 [CTL.YAML] bfw_power_normalization_alg_selector: 0
07:24:32.816478 CON phy_init 0 [CTL.YAML] bfw_beta_prescaler: 2048
07:24:32.816478 CON phy_init 0 [CTL.YAML] total_num_srs_chest_buffers: 6144
07:24:32.816478 CON phy_init 0 [CTL.YAML] ul_pcap_capture_enable: 1
07:24:32.816478 CON phy_init 0 [CTL.YAML] ul_pcap_capture_thread_cpu_affinity: 19
07:24:32.816478 CON phy_init 0 [CTL.YAML] ul_pcap_capture_thread_sched_priority: 95
07:24:32.816478 CON phy_init 0 [CTL.YAML] ul_order_timeout_gpu_log_enable: 0
07:24:32.816479 CON phy_init 0 [CTL.YAML] pusch_workCancelMode: 2
07:24:32.816479 CON phy_init 0 [CTL.YAML] GPU-initiated comms DL: 1
07:24:32.816479 CON phy_init 0 [CTL.YAML] GPU-initiated comms (via CPU): 0
07:24:32.816479 CON phy_init 0 [CTL.YAML] CPU-initiated comms : 0
07:24:32.816479 CON phy_init 0 [CTL.YAML] Cell group: 1
07:24:32.816479 CON phy_init 0 [CTL.YAML] Cell group num: 1
07:24:32.816480 CON phy_init 0 [CTL.YAML] puxchPolarDcdrListSz: 8
07:24:32.816480 CON phy_init 0 [CTL.YAML] split_ul_cuda_streams: 0
07:24:32.816480 CON phy_init 0 [CTL.YAML] serialize_pucch_pusch: 0
07:24:32.816480 CON phy_init 0 [CTL.YAML] Number of Cell Configs: 1
07:24:32.816480 CON phy_init 0 [CTL.YAML] L2Adapter config file: /opt/nvidia/cuBB/cuPHY-CP/cuphycontroller/config/l2_adapter_config_F08_CG1.yaml
07:24:32.816480 CON phy_init 0 [CTL.YAML] Cell name: O-RU 0
07:24:32.816481 CON phy_init 0 [CTL.YAML]       MU: 1
07:24:32.816481 CON phy_init 0 [CTL.YAML]       ID: 1
07:24:32.816481 CON phy_init 0 [CTL.YAML] Number of MPlane Configs: 1
07:24:32.816481 CON phy_init 0 [CTL.YAML]       Mplane ID: 1
07:24:32.816481 CON phy_init 0 [CTL.YAML]       VLAN ID: 2
07:24:32.816481 CON phy_init 0 [CTL.YAML]       Source Eth Address: 00:00:00:00:00:00
07:24:32.816481 CON phy_init 0 [CTL.YAML]       Destination Eth Address: 20:04:9b:9e:27:a3
07:24:32.816481 CON phy_init 0 [CTL.YAML]       NIC port: 0002:01:00.0
07:24:32.816482 CON phy_init 0 [CTL.YAML]       RU Type: 3
07:24:32.816482 CON phy_init 0 [CTL.YAML]       U-plane TXQs: 1
07:24:32.816482 CON phy_init 0 [CTL.YAML]       DL compression method: 1
07:24:32.816482 CON phy_init 0 [CTL.YAML]       DL iq bit width: 9
07:24:32.816482 CON phy_init 0 [CTL.YAML]       UL compression method: 1
07:24:32.816482 CON phy_init 0 [CTL.YAML]       UL iq bit width: 9
07:24:32.816482 CON phy_init 0 [CTL.YAML]       Flow list SSB/PBCH:
07:24:32.816482 CON phy_init 0 [CTL.YAML]               8
07:24:32.816482 CON phy_init 0 [CTL.YAML]               0
07:24:32.816483 CON phy_init 0 [CTL.YAML]               1
07:24:32.816483 CON phy_init 0 [CTL.YAML]               2
07:24:32.816483 CON phy_init 0 [CTL.YAML]       Flow list PDCCH:
07:24:32.816483 CON phy_init 0 [CTL.YAML]               8
07:24:32.816483 CON phy_init 0 [CTL.YAML]               0
07:24:32.816483 CON phy_init 0 [CTL.YAML]       Flow list PDSCH:
07:24:32.816483 CON phy_init 0 [CTL.YAML]       Flow list CSIRS:
07:24:32.816484 CON phy_init 0 [CTL.YAML]               2
07:24:32.816484 CON phy_init 0 [CTL.YAML]       Flow list PUSCH:
07:24:32.816484 CON phy_init 0 [CTL.YAML]               8
07:24:32.816484 CON phy_init 0 [CTL.YAML]               0
07:24:32.816484 CON phy_init 0 [CTL.YAML]               1
07:24:32.816484 CON phy_init 0 [CTL.YAML]       Flow list PUCCH:
07:24:32.816484 CON phy_init 0 [CTL.YAML]       Flow list SRS:
07:24:32.816485 CON phy_init 0 [CTL.YAML]               0
07:24:32.816485 CON phy_init 0 [CTL.YAML]               1
07:24:32.816485 CON phy_init 0 [CTL.YAML]               2
07:24:32.816485 CON phy_init 0 [CTL.YAML]       Flow list PRACH:
07:24:32.816485 CON phy_init 0 [CTL.YAML]               15
07:24:32.816485 CON phy_init 0 [CTL.YAML]               7
07:24:32.816485 CON phy_init 0 [CTL.YAML]       PUSCH TV: /opt/nvidia/cuBB/testVectors/cuPhyChEstCoeffs.h5
07:24:32.816485 CON phy_init 0 [CTL.YAML]       SRS TV: /opt/nvidia/cuBB/testVectors/cuPhyChEstCoeffs.h5
07:24:32.816485 CON phy_init 0 [CTL.YAML]       Section_3 time offset: 58369
07:24:32.816485 CON phy_init 0 [CTL.YAML]       nMaxRxAnt: 4
07:24:32.816485 CON phy_init 0 [CTL.YAML]       PUSCH PRBs Stride: 273
07:24:32.816486 CON phy_init 0 [CTL.YAML]       PRACH PRBs Stride: 12
07:24:32.816486 CON phy_init 0 [CTL.YAML]       SRS PRBs Stride: 273
07:24:32.816486 CON phy_init 0 [CTL.YAML]       PUSCH nMaxPrb: 273
07:24:32.816486 CON phy_init 0 [CTL.YAML]       PUSCH nMaxRx: 4
07:24:32.816486 CON phy_init 0 [CTL.YAML]       UL Gain Calibration: 48.68
07:24:32.816486 CON phy_init 0 [CTL.YAML]       Lower guard bw: 845
07:24:32.985697 CON phy_init 0 [CTL.SCF] Network interface for PCIe address 0002:01:00.0 : enP2s2f0np0
07:24:32.985749 CON phy_init 0 [APP.UTILS]           PHC clock: 1756193070.517354396
07:24:32.985762 CON phy_init 0 [APP.UTILS]           CLOCK_TAI: 1756193072.985756401
07:24:32.985762 CON phy_init 0 [APP.UTILS]      CLOCK_REALTIME: 1756193072.985756369
07:24:32.985762 CON phy_init 0 [APP.UTILS] TAI/REALTIME offset: 0 seconds
07:24:32.988110 CON phy_init 0 [DRV.CTX] CUDA_DEVICE_MAX_CONNECTIONS 8
07:24:32.988114 CON phy_init 0 [DRV.CTX] use_green_contexts 0
EAL: Detected CPU lcores: 72
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/cuphycontroller/mp_socket
EAL: Selected IOVA mode 'VA'
EAL: VFIO support initialized
EAL: Probe PCI driver: gpu_cuda (10de:2342) device: 0009:01:00.0 (socket 0)
[07:24:34:282035][385344][DOCA][ERR][doca_eth_txq.c:3528][doca_eth_txq_cap_get_wait_on_time_offload_supported] DEVINFO 0x3bb18d65160: Failed to get wait_on_time_offload_supported: querying capabilities failed. err=DOCA_ERROR_NOT_SUPPORTED
EAL: Probe PCI driver: mlx5_pci (15b3:a2dc) device: 0002:01:00.0 (socket 0)
07:24:34.282045 ERR phy_init 0 [AERIAL_DPDK_API_EVENT] [FH.NIC] doca_eth_txq_get_wait_on_time_offload_supported returned Operation not supported
[07:24:34:679971][385344][DOCA][ERR][doca_eth_txq.c:3528][doca_eth_txq_cap_get_wait_on_time_offload_supported] DEVINFO 0x3bb18d65160: Failed to get wait_on_time_offload_supported: querying capabilities failed. err=DOCA_ERROR_NOT_SUPPORTED
[07:24:34:679984][385344][DOCA][ERR][doca_eth_txq.c:2169][eth_txq_start_gpu_ctx] ETH_TXQ 0x3bb19d89f80: Failed to start txq: failed to get wait on time offload capability. err=DOCA_ERROR_NOT_SUPPORTED
[07:24:34:679988][385344][DOCA][ERR][doca_pe.cpp:1016][start_context] Progress engine 0x3bb18d684c0: Failed to start context=0x3bb19d89f80. err=DOCA_ERROR_NOT_SUPPORTED
07:24:34.702634 FATAL exit: Thread [phy_drv_init] on core 23 file /opt/nvidia/cuBB/cuPHY-CP/cuphycontroller/examples/cuphycontroller_scf.cpp line 342: additional info: NULL
07:24:34.679990 ERR phy_init 0 [AERIAL_INVALID_PARAM_EVENT] [FH.DOCA] Failed doca_ctx_start: Operation not supported
07:24:34.691628 ERR phy_init 0 [AERIAL_ORAN_FH_EVENT] [FH.LIB] Exception! Failed to setup DOCA GPU TxQ #60 on NIC 0002:01:00.0 because doca_create_tx_queue was a failure
07:24:34.691636 ERR phy_init 0 [AERIAL_ORAN_FH_EVENT] [DRV.FH] Failed to add NIC 0002:01:00.0
07:24:34.702596 ERR phy_init 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.EXCP] /opt/nvidia/cuBB/cuPHY-CP/cuphydriver/src/common/cuphydriver_api.cpp l1_init line 132 exception: NIC registration error
07:24:34.702611 ERR phy_init 0 [AERIAL_CUPHYDRV_API_EVENT] [CTL.DRV] Error l1_init
07:24:34.702613 ERR phy_init 0 [AERIAL_CUPHYDRV_API_EVENT] [CTL.SCF] pc_init_phydriver error -1
07:24:34.702648 FAT phy_init 0 [AERIAL_SYSTEM_API_EVENT] [NVLOG.EXIT_HANDLER] FATAL exit: Thread [phy_drv_init] on core 23 file /opt/nvidia/cuBB/cuPHY-CP/cuphycontroller/examples/cuphycontroller_scf.cpp line 342: additional info: NULL
Stack trace (most recent call last):
#6    Object "/usr/lib/aarch64-linux-gnu/ld-linux-aarch64.so.1", at 0xffffffffffffffff, in
#5    Object "/opt/nvidia/cuBB/build/cuPHY-CP/cuphycontroller/examples/cuphycontroller_scf", at 0x41e1ef, in _start
#4    Object "/usr/lib/aarch64-linux-gnu/libc.so.6", at 0xff8d0a2874cb, in __libc_start_main
#3    Object "/usr/lib/aarch64-linux-gnu/libc.so.6", at 0xff8d0a2873fb, in
#2    Object "/opt/nvidia/cuBB/build/cuPHY-CP/cuphycontroller/examples/cuphycontroller_scf", at 0x411e6b, in main
#1    Object "/opt/nvidia/cuBB/build/cuPHY/nvlog/libnvlog.so", at 0xff8d0a6fcf2b, in exit_handler::test_trigger_exit(char const*, int, char const*)
07:24:34.802719 CON phy_init 0 [DRV.API] Triggering L1 exit handler
#0    Source "/opt/nvidia/cuBB/cuPHY-CP/cuphydriver/src/common/cuphydriver_api.cpp", line 2856, in l1_exit_handler
       2853:     //PhyDriver initialization failure
       2854:     if(l1_getPhydriverHandle() == nullptr)
       2855:     {
      >2856:         AERIAL_PRINT_BACKTRACE(32ULL);
       2857:         std::exit(EXIT_FAILURE); //Exit immediately
       2858:     }
Could you please give me some advice to solve the problem?
Hi @benji_huang ,
Welcome to our community!
Could you please verify that the configurations written in section “Update BF3 BFB Image and NIC Firmware” have been successfully performed, and that you can observe the expected output using the following command?
$ sudo mlxconfig -d /dev/mst/mt41692_pciconf0 q | grep "CQE_COMPRESSION\|PROG_PARSE_GRAPH\|ACCURATE_TX_SCHEDULER\|FLEX_PARSER_PROFILE_ENABLE\|REAL_TIME_CLOCK_ENABLE\|INTERNAL_CPU_MODEL\|LINK_TYPE_P1\|LINK_TYPE_P2\|INTERNAL_CPU_PAGE_SUPPLIER\|INTERNAL_CPU_ESWITCH_MANAGER\|INTERNAL_CPU_IB_VPORT0\|INTERNAL_CPU_OFFLOAD_ENGINE"
        INTERNAL_CPU_MODEL                  EMBEDDED_CPU(1)
        INTERNAL_CPU_PAGE_SUPPLIER          EXT_HOST_PF(1)
        INTERNAL_CPU_ESWITCH_MANAGER        EXT_HOST_PF(1)
        INTERNAL_CPU_IB_VPORT0              EXT_HOST_PF(1)
        INTERNAL_CPU_OFFLOAD_ENGINE         DISABLED(1)
        FLEX_PARSER_PROFILE_ENABLE          4
        PROG_PARSE_GRAPH                    True(1)
        ACCURATE_TX_SCHEDULER               True(1)
        CQE_COMPRESSION                     AGGRESSIVE(1)
        REAL_TIME_CLOCK_ENABLE              True(1)
        LINK_TYPE_P1                        ETH(2)
        LINK_TYPE_P2                        ETH(2)
Thank you.
Hi
This step has already been completed, and the command output is the same as expected.
        LINK_TYPE_P1                                ETH(2)
        LINK_TYPE_P2                                ETH(2)
Many thanks.
I think you are using the second BF3 card (PCI Device Name: 0002:01:00.0 or /dev/mst/mt41692_pciconf1). Is the output for the second one the same?
I’ve resolved the issue. It seems I may have forgotten to perform a cold boot during the BF3 firmware update step. After doing a full power cycle, the error log no longer appears.
Thank you for your help.
