Does the NVIDIA Tegra K1 platform provide hardware accelerated, stateless AES Encryption/Decryption Algorithms (independent of the output of the previous packet of encryption/decryption, counters or the like)?
In the kernel compile config, I see CONFIG_CRYPTO_AES_ARM. The help menu on the config says “Use optimized AES assembler routines for ARM platforms”. This would not be CUDA accelerated, but it would probably take advantage of the NEON instruction set for ARMv7. You’d have to look at that driver’s source to see exactly how it does this.
I believe that the Grinch kernel has the TEGRA AES hardware engine enabled.
