Hi everyone,
I try to download and compile kernel source, and flash follow the guide:
[url]How to build NVIDIA Jetson Nano kernel - RidgeRun Developer Connection
But When I flash kernel image follow steps of section “Flash Custom Kernel Image”, after reboot there is an error when booting: “[FAILED] Failed to start Resize SD Card root partition and filesystem.” and halted with “Host read timeout at address 5458045c” print
Does anyone know what’s problem?
I appreciated for any suggestion
Do you modify anything in kernel source?
If not, do you remember to add extra version “-tegra” during compilation?
Hi Wayne,
Thanks for your reply
I didn’t modify anything, I just lost one step…:P
Execute the following commands to install the kernel modules:
$ sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install \
INSTALL_MOD_PATH=Linux_for_Tegra/rootfs/
now the system can boot success. but [FAILED] Failed to start Resize SD Card root partition and filesystem still exist.
Hi zhaoxiang,
This should not be a fatal error. It is known warning message.
