Jetson Tegra K1 won’t boot after flashing
Description:
I downloaded the Tegra124_Linux_R19.2.0_armhf.tbz2 and Tegra_Linux_Sample-Root-Filesystem_R19.2.0_armhf.tbz2 from Linux For Tegra R19 | NVIDIA Developer
After this I flashed the Jetson according to the description there :
./flash.sh -S 8GiB jetson-tk1 mmcblk0p1
All went well : no errors whatsoever, but after rebooting the jetson now gives a kernel panic saying :
Cannot open root device “mmcblk0p1” or unknown-block(179,1): error -6
Any ideas ? I can’t find anything wrong in what I did so I wonder if it may be a bug in the bootloader settings ?
Casey
Hi, I have reflashed mine a couple of times and have not encountered this error.
However: did you remember to build the rootfs?
http://developer.download.nvidia.com/embedded/L4T/r19_Release_v1.0/l4t_quick_start_guide.txt
Your bootloader settings look okay, and the only two things I can think of would have to do with either a defective eMMC (onboard MMC) or didn’t put the rootfs in the right place. From the directory where you ran the flash utility, see also the jetson-tk1.conf file.
I did rebuild the rootfs : it is there.
But I also edited the jetson-tk1.conf and changed the EMMCSIZE as I (wrongly) assumed this was recommended in the release notes. However this turns out to be the physical size of the on board storage and NOT the partition size ! Stupid of me.
I am now flashing again and hope for the best …
Casey
I flashed it again and it works fine now !
Sorry for wasting your time …
Casey
