After Nvidia Driver Install on Debian laptop's main monitor is black and second monitor is working perfectly
I did a fresh install of Debian 12 on my laptop.
SecureBoot always became disabled.
My laptop hardwares are as follows:
KERNEL : 6.1.0-37-amd64
CPU : Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (12 Core)
GPU : 00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
01:00.0 VGA compatible controller: NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] (rev a1)
ENVIRONMENT : GNOME
I successfully installed the nvidia-driver package which i downloaded from NVIDIA’s website. Before i installed i was able to use my laptop’s main monitor and other external monitor. After install my laptop’s monitor working only at grub, and all the other time i am using second monitor. Even if i plug out the second monitor still laptop giving me black screen.
Setup and environment information
All commands and output provided below were ran with the external monitor connected to the laptop.
Output for xrandr
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 32767 x 32767
HDMI-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440     59.95 + 144.00*  119.99
   2560x1080     59.94
   1920x1080     60.00    59.94    50.00
   1680x1050     59.95
   1600x900      60.00
   1440x900      59.89
   1280x1440     60.00
   1280x1024     75.02
   1280x960      60.00
   1280x720      60.00    59.94    50.00
   1152x864      75.00
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       59.94
   640x480       75.00    59.94    59.93
Output for xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x1b7 cap: 0x1, Source Output crtcs: 4 outputs: 1 associated providers: 0 name:NVIDIA-0
Output for xrandr --listmonitors
Monitors: 1
 0: +*HDMI-0 2560/597x1440/336+0+0  HDMI-0
Output for inxi -G
Graphics:
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
  Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] driver: nvidia
    v: 575.64
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 1.21.1.7 with: Xwayland v: 22.1.9 driver: X:
    loaded: nvidia gpu: i915 resolution: 2560x1440
  API: OpenGL v: 4.6.0 NVIDIA 575.64 renderer: NVIDIA GeForce GTX 1660 Ti
    with Max-Q Design/PCIe/SSE2
Output for sudo lshw -c video
  *-display
       description: VGA compatible controller
       product: TU116M [GeForce GTX 1660 Ti Mobile]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
       configuration: driver=nvidia latency=0
       resources: irq:151 memory:a2000000-a2ffffff memory:90000000-9fffffff memory:a0000000-a1ffffff ioport:4000(size=128) memory:a3000000-a307ffff
  *-display
       product: CoffeeLake-H GT2 [UHD Graphics 630]
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       logical name: /dev/fb0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
       configuration: depth=32 driver=i915 latency=0 resolution=1920,1080
       resources: irq:142 memory:a4000000-a4ffffff memory:80000000-8fffffff ioport:5000(size=64) memory:c0000-dffff
Output for lsmod | grep nvidia
nvidia_uvm           1810432  40
nvidia_drm            118784  51
nvidia_modeset       1732608  29 nvidia_drm
nvidia              11476992  1030 nvidia_uvm,nvidia_modeset
drm_kms_helper        212992  5 bochs,drm_vram_helper,drm_display_helper,nvidia_drm,i915
drm                   614400  59 drm_kms_helper,bochs,drm_vram_helper,drm_display_helper,nvidia,drm_buddy,drm_ttm_helper,nvidia_drm,i915,ttm
video                  65536  4 dell_wmi,dell_laptop,i915,nvidia_modeset
What I have tried
set kernel parameter
nvidia-drm.modeset=1
and reboot, then run
xrandr --setprovideroutputsource NVIDIA-G0 modesetting && xrandr --auto
Reply from terminal: Could not find provider with name NVIDIA-G0
You use X11 not Wayland, correct? Assuming so, most probably X has not autoconfigured itself to use displays connected to the Intel GPU. Try configuring it manually by adding a file with the following contents somewhere in /etc/X11/xorg.conf.d/ folder:
Section "Device"
        Identifier "Intel"
        Driver "modesetting"
        BusID "PCI:0:2:0"
EndSection
Section "Device"
        Identifier "Nvidia"
        Driver "nvidia"
        Option "AllowEmptyInitialConfiguration" "true"
        BusID "PCI:1:0:0"
EndSection
Section "Screen"
        Identifier "dualGPU"
        Device "Nvidia"  ## primary GPU performing the rendering
        GPUDevice "Intel"  ## secondary GPU providing additional monitors
EndSection
On a side note:
This was released in 2022… I think there are some newer kernels available in backports, but generally Debian-12 is a pretty old system. I’d recommend going with Debian-13 which is currently in RC stage and has been perfectly stable for over a year now. You can then use Nvidia apt repos for Debian-12: they work fine with 13 as well.
Thanks it worked!!!
Thanks for suggestion, i will consider :))
