Hi jameskuo,
Could you refer to the steps in SMCU update bug on BMC UI update - #8 by KevinFFF to update the following SMCU FW to verify? P3740_Aurix_StepB.hex (1.3 MB)
If you update it successfully, you should get the following information.
Shell>version P3740-QS2 with TLF35584 B/C-Step SW Version 1.50.15 * Rel-36 DP release TC397 Step BD
Hi KevinFFF: Thanks for the reply. We just tested 50 times poweroff. Results seems OK. This issue is not happening, we can always poweroff the system then power on the system via power btn again.
poweroff
Thank you again for the support.
