I rebuilt the kernel to use MIDI with Jetson Orin and now the logon screen does not appear. The serial log shows the following error
[ 12.448722] nvidia: loading out-of-tree module taints kernel.
[ 12.456438] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 12.467001] nvidia: disagrees about version of symbol filp_open
[ 12.473856] nvidia: Unknown symbol filp_open (err -22)
[ 12.479809] nvidia: disagrees about version of symbol __put_page
[ 12.487055] nvidia: Unknown symbol __put_page (err -22)
The following repository at JetsonHacks is used as a reference.
What, is there an error?
seems like this repo does not support Orin series and L4T releases newer than r32.7.2.
Are you sure it works? It also does not seem to be something we should support, as it’s a third-party work.
disagrees about version of symbol XXX usually means the kernel module is not built for the specific version of kernel images running on the system.
I meet the same problem,Do you solve the problem?
Hi koudaj,
Have you managed to get issue resolved or still need the support? Thanks
koudaj
May 23, 2023, 10:27am
6
Connecting from outside via SSH, the logon screen was displayed by following the steps below.
sudo systemctl set-default multi-user.target
sudo reboot
wget https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v3.1/sources/public_sources.tbz2
tar xvf public_sources.tbz2
cd Linux_for_Tegra/source/public/
tar xvf kernel_src.tbz2
tar xvf nvidia_kernel_display_driver_source.tbz2
cd kernel/kernel-5.10
sudo apt install -y libncurses5-dev libssh-dev
zcat /proc/config.gz > .config
make menuconfig
make prepare
make modules_prepare
make -j8 Image && make -j8 modules
sudo make modules_install
sudo cp arch/arm64/boot/Image /boot/Image
cd …/…/NVIDIA-kernel-module-source-TempVersion/
make -C $PWD modules -j8 SYSSRC=$PWD/…/kernel/kernel-5.10/
sudo make modules_install -j8
sudo systemctl set-default graphical.target
sudo reboot
system
Closed
June 6, 2023, 11:53pm
8
