ExtLinuxBoot:Failed to open file:\boot\initrd Not Found.
L4TLauncher:Unable to boot via extlinux:Not Found.
Hi 978466899,
What’s image are you using?
Are you reproduce issue every time?
Hi carolyuu,
What’s image are you using? I don’t understand.
Are you reproduce issue every time? Yes.
Which jetpack version are you using…
We don’t sure what jetpak version we are using. Sorry, We installed it with command and paid no attention to the version.
Then flash it again and tell me what version in use.
Also, is this Orin devkit or some custom carrier board?
Did you flash the unit before? If so, what directories do you see in:
ls -d ~/nvidia/nvidia_sdk/*
If there is a subdirectory with a release version named after JetPack 5, then within that the “Linux_for_Tegra/rootfs/etc/nv_tegra_release” file (the first line in it) would name what release was flashed.
I also saw a mention in the video of a test key. I’m not sure what this is, but perhaps it is the security fuse? Not sure, but have you ever flashed it with security fuse burn?
