AGX/IGX best fit solution for 106 FPS
Customer is looking for a AGX/IGX Orin Series Solution to support 110 (FPS) – ( Frame Rate Per second).
What Ampere architecture/Tensor Core CPU would make sense for this frame rate?
Should I be somewhere close to 200 TOPS or would 100 TOPs be plenty to support this frame rate.
Application is face tracking within surgery. The Dr is wearing head gear with a camera as it moves within surgery.
For information, do you use HDMI in as camera sensor input? How many camera inputs are in the use-case?
