caper@caper-desktop:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 ! 'video/x-raw(memory:NVMM), width=(int)3864, height=(int)2180, format=(string)NV12, framerate=(fraction)60/1' ! nvvidconv ! xvimagesink -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3864 x 2180 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 3981.070801; Exposure Range min 30000, max 500000000;
GST_ARGUS: 3864 x 2180 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 3981.070801; Exposure Range min 30000, max 500000000;
GST_ARGUS: 1944 x 1090 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 3981.070801; Exposure Range min 30000, max 500000000;
GST_ARGUS: 1944 x 1090 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 3981.070801; Exposure Range min 30000, max 500000000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 1
Output Stream W = 3864 H = 2180
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
NvDdkVicExecute Failed
nvbuffer_transform Failed
gst_nvvconv_transform: NvBufferTransform Failed
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason error (-5)
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:01.196924048
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
(Argus) Error FileOperationFailed: Failed socket read: Connection reset by peer (in src/rpc/socket/common/SocketUtils.cpp, function readSocket(), line 79)
(Argus) Error FileOperationFailed: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error FileOperationFailed: Receive worker failure, notifying 3 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 3 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error FileOperationFailed: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error FileOperationFailed: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error FileOperationFailed: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Caught SIGSEGV
CONSUMER: Done Success
Please try
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 ! 'video/x-raw(memory:NVMM), width=(int)3864, height=(int)2180, format=(string)NV12, framerate=(fraction)60/1' ! nvvidconv ! video/x-raw,format=I420 ! xvimagesink -e
still not working, will flash out a pic then crash. For both posted command.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 ! ‘video/x-raw(memory:NVMM), width=(int)3864, height=(int)2180, format=(string)NV12, framerate=(fraction)60/1’ ! nvvidconv ! video/x-raw,format=I420 ! xvimagesink -e
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
CONSUMER: Waiting until producer is connected…
Camera index = 0
Camera mode = 1
seconds to Run = 0
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error EndOfFile: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD… Exiting…
Got EOS from element “pipeline0”.
Execution ended after 0:00:01.004348119
Setting pipeline to READY …
Caught SIGSEGV
It seems like the sensor driver is not ready. Please check if you can run this command:
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 ! 'video/x-raw(memory:NVMM), width=(int)3864, height=(int)2180, format=(string)NV12, framerate=(fraction)60/1' ! fakesink
If not, you would need to refer to sensor driver programming guide and check sensor driver.
still not working, where can i found the ‘sensor driver programming guide’ and how to check sensor driver
$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 sensor-mode=1 ! ‘video/x-raw(memory:NVMM), width=(int)3864, height=(int)2180, format=(string)NV12, framerate=(fraction)60/1’ ! fakesink
Camera index = 0
Camera mode = 1
seconds to Run = 0
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: DISCONNECTED
Argus Error Status
Execution ended after 0:00:01.456456992
CONSUMER: ERROR OCCURRED
Caught SIGSEGV
Not sure you use Jetpack 4 or Jetpack 5. For Jetpack 4, please check:
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3261/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/camera_sensor_prog.47.1.html#
And do you use camera board from our camera partner? Please share information about the camera board you are using for reference.
I am using jp 4.6.2 with Xavier 4 sensor adaptor board v1.1 108.12.26, and actually i have serval board and all of the m pop up the same error msg
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
It is uncertain which camera board you use. Do you have web link to the board? Like this
