AGX Orin 32G flash failed when upgrade jetpack from 5.0.2 to 5.1.2
Environmental configuration:
os:unbuntu18.04
hardware: out board + agx_orin_32G_module
jetpack_Ver:5.0.2
flash_result: success
os:unbuntu18.04
jetpack_Ver:5.1.2
flash_result: failed
I can flash arg_orin_32G module through sdkmanager when jetpack version is 5.0.2. It will flash failed when upgrade jetpack to 5.1.2.
sdkmanager log and device serial log as flollows, please help to check why it flash failed when jetpack is 1.1.2. Thanks.
SDKM_logs_JetPack_5.0.2_(rev._2)_Linux_for_Jetson_AGX_Orin_modules_2023-08-19_09-41-19.zip (136.7 KB)
SDK_5.1.2_err.zip (105.7 KB)
serial_5.0.2_ok.txt (22.1 KB)
serial_5.1.2_err.log (43.9 KB)
what do you mean with out board?
Is it a DevKit or a custom carrier board?
The log looks like from a custom board. Please contact board vendor for customization BSP if you are not the board vendor.
The board is custom board, but It’s ok when I used jetson 5.0.2. It flashed failed when I update jetson verison to 5.1.2. Are there any differences between the two versions?
As Wayne said, please always contact the board vendor for the customized BSP.
Our original BSP is only intended for DevKits from NVIDIA.
