When starting flash jetson linux, flash failed
Hi, all
I’m trying to flash my Orin dev kit to JetPack 5.1, flash config is “Manual" and "Runtime”.
After “Jetson Linux Image” dowloaded and “OS image ready”, “Flash Jetson Linux” progress is about 1%, suddenly Orin USB disconnected, flash failed.
Error log from SDK Manager Terminal:
17:47:24 INFO: Flash Jetson Linux - flash: --- Reading board information succeeded.
17:47:24 INFO: Flash Jetson Linux - flash: Parsing module EEPROM:
17:47:24 INFO: Flash Jetson Linux - flash: --- Parsing board ID (3701) succeeded.
17:47:24 INFO: Flash Jetson Linux - flash: --- Parsing board version (500) succeeded.
17:47:24 INFO: Flash Jetson Linux - flash: --- Parsing board SKU (0005) succeeded.
17:47:24 INFO: Flash Jetson Linux - flash: --- Parsing board REV (M.0) succeeded.
17:47:24 ERROR: Flash Jetson Linux - flash: Error: Target board not found.
17:47:24 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
17:47:24 INFO: Flash Jetson Linux - flash: [host] [ 4.59 MB released. Disk Avail: 53.83 GB ]
17:47:24 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 10s ]
17:47:24 ERROR: Flash Jetson Linux - flash: command terminated with error
17:47:24 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
Full log:
orin_flash.log (9.6 KB)
Does anyone have this situation?
Hi mouyun1115,
It seems you are using 64GB Orin AGX (p3701-0005 ), which is not supported in Jetpack 5.1.
Please try current Jetpack 5.1.1(R35.3.1) for your devkit.
Devices Supported by This Document
Hi @KevinFFF ,
I have tried Jetpack 5.1.1(R35.3.1), and everything is going well! Thank you very much!
