Flash Failure on Jetson Orin 64GB Dev Kit using Jetpack 5.0.2
Hi, I have a problem in the process of flashing the Nvidia Jetson orin developer kit 64GB.
There was no problem when I flash with Jetpack 5.1.1.
I’m trying to flash it again with Jetpack 5.0.2, I met the error as the picture below.
I tried with 2 Nvidia Jetson orin developer kit 64GB, all showing the same error.
But, with Nvidia Jetson orin developer kit 32GB, I succeeded in flashing with Jetpack 5.0.2 and 5.1.1 without any problems.
Can’t Nvidia Jetson orin developer kit 64GB flash with Jetpack 5.0.2?
I will also share the contents of the terminal.
There is an error line on the last line.
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.2135 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.2274 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.2356 ] Assuming zero filled SBK key
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.2443 ] MB1-BCT version: 0.9
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.2486 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.2620 ] adding BCH for mb1_bct_MB1_aligned.bct
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.2703 ] Assuming zero filled SBK key
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.2930 ] BR_CID: 0x80012344705DE1E2780000000A030140
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.3548 ] Sending bct_br
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.4102 ] Sending mb1
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.4192 ] Sending bct_mb1
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.4363 ] adding BCH for applet_t234_aligned.bin
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.4620 ] Assuming zero filled SBK key
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.4717 ] BL: version 0.23.0.0-t234-54845784-92215740 last_boot_error: 0
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.6102 ] Sending applet
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.7333 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.7358 ] MB2 Applet version 01.00.0000
18:27:35 INFO: Flash Jetson AGX Orin - flash: [ 0.9290 ] MB2 Applet version 01.00.0000
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 0.9917 ] MB2 Applet version 01.00.0000
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.0534 ] Chip Sample: prod
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.0568 ] MB2 Applet version 01.00.0000
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.1120 ] Saved platform info in /home/sol/nvidia/nvidia_sdk/JetPack_5.0.2_Runtime_Linux_Runtime_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.1490 ] MB2 Applet version 01.00.0000
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.2092 ] MB2 Applet version 01.00.0000
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.2689 ] MB2 Applet version 01.00.0000
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.3239 ] Saved bct in tmp.bct
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.3335 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/sol/nvidia/nvidia_sdk/JetPack_5.0.2_Runtime_Linux_Runtime_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.4010 ] MB2 Applet version 01.00.0000
18:27:36 INFO: Flash Jetson AGX Orin - flash: [ 1.4615 ] MB2 Applet version 01.00.0000
18:27:38 INFO: Flash Jetson AGX Orin - flash: Board ID(3701) version(500) sku(0005) revision(P.0)
18:27:38 INFO: Flash Jetson AGX Orin - flash: Usage: sudo ./flash.sh [options] t186ref mmcblk0p1
18:27:38 INFO: Flash Jetson AGX Orin - flash: --sign ---------------- Sign images and store them under “bootloader/signed”
18:27:38 ERROR: Flash Jetson AGX Orin - flash: command terminated with error
18:27:38 SUMMARY: DateTime Target Setup - target: Depends on failed component
I have same issue.
what’s going on?
Yes, jp5.0.2 cannot flash Orin64GB. This module was released after jp5.0.2.
You need to use at least jp5.1.1 to flash this module.
