Got some errors during flashing jetpack 6.0 from ubuntu 20.04
Device turning on. It’s preconfigured, but do not react to any mouse or keyboard. Here is the log
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_AGX_Orin_32GB_2024-11-05_14-56-20.zip (303.5 KB)
I would like to ask the following questions for further check.
- Could you confirm whether your Ubuntu system is running on a physical machine or a virtual machine?
- Is your AGX Orin a developer kit or using a custom carrier board?
Additionally, you can try the following commands:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
And run the SDK Manager again.
system
Closed
6
