Hi NV team
We have AGX ORIN issue while booting,stuck at "Enabling combined UART " message
It seems like a hardware checking situation
is possible to know which component fault?
attach file is ORIN console
ORINfail.txt (45.8 KB)
Hi NV team
What L4T version?
Is is a DevKit or a custom carrier board?
Was the device working properly with the same BSP before?
Hi
L4T version is R35.3.1
It work fine on DevKit & custom carrier board before
but after "Enabling combined UART " message ,ORIN not work on both carrier board
I tried to recovery with official image with SDK manager,show same message on DevKit
I am asking did you make any change to the BSP, which may have caused this issue, or it just broke while it was working fine before?
Re-flashing with the official image of course does not work with a custom board. You should know what can be flashed into the board.
Result of Re-flashing official image is “not” on custom board is on DevKit carrier board!!
BSP changes I need to confirm with software engineer
hi DaveYYY
attach txt file is ORIN normal operation console on our custom board
the hardware & software setting is same with the fail ORIN
ORIN0219_normal.txt (96.1 KB)
Then will it work if you put the module of the device that fails to boot up on another carrier board that was working fine before?
