AGX Orin custom carrier board flash fail
Hi Nvidia,
We have a custom carrier board based on AGX Orin Devkit.
I uesd L4T36.4.0 to flash it.
I just modify 2 differents:
  1. vim bootloader/tegra234-mb2-bct-common.dtsi
cvb_eeprom_read_size = <0x0>;
  1. vim p3701.conf.common
ODMDATA="gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0";
Flash command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs jetson-agx-orin-devkit nvme0n1p1
We got timeout in the flash Step 3.
The debug log is hang in UEFI few minutes then reboot:
??NOTICE:  BL31: v2.8(release):e12e3fa93
NOTICE:  BL31: Built : 21:01:44, Sep 12 2024
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Fri Sep 13 04:10:17 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
I/TC: Primary CPU switching to normal world boot
  Jetson UEFI firmware (version 36.4.0-gcid-37537400 built on 2024-09-13T04:02:39+00:00)
??[     8.252822] Camera-FW on t234-rce-safe started
TCU early console enabled.
  ??[     8.305273] Camera-FW on t234-rce-safe ready SHA1=e2238c99 (crt 0.895 ms, total boot 53.398 ms)
Upload the full debug uart log.
AGX_Orin_Custmor_Boot_Error.txt (79.3 KB)
Please help us.
use the below command to flash:
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 *
** -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” *
** --showlogs --network usb0 jetson-orin-nano-devkit internal**
reference link:
Hi nagesh_accord,
I’m using AGX Orin. Your command is for Orin Nano.
But Thanks replay.
It appears to be discussed in this topic
Please follow the quick start guide using flash.sh whether flashing succeed
sudo ./flash.sh jetson-agx-orin-devkit internal
