AGX Orin Flash Error
Hello, I use a customized board for Flash test
But it’s stuck at “waiting for target to boot-up…”
Flash cmd : sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-agx-orin-devkit external
Modified cvb_eeprom_read_size in tegra234-mb2-bct-common.dtsi to <0x0>
Where there is no setting or error?
AGX_Orin_Flash_Error.log (45.7 KB)
From your log,
FATAL ERROR [FILE=platform/drivers/uphy/uphy-tegra234.c, ERR_UID=2251]: start PLL 8 calibration failed
Seems you apply the default ODMDATA leading failed error.
Please follow the guide to modify the ODMDATA based on your hardware design.
Hello @DavidDDD ,
I have modify ODMDATA to
ODMDATA=“gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0”;
And also reflash QSPI
$ sudo ./flash.sh -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-agx-orin-devkit nvme0n1p1
But it also didn’t work
Still stopped at “waiting for target to boot-up…”
AGX_Orin_Flash_Error_1.log (42.2 KB)
It appears that a different bug occured.
Please build the uefi_Jetson_DEBUG.bin from GitHub - NVIDIA/edk2-nvidia: NVIDIA EDK2 platform support with your JP version.
Replace it to bootloader/uefi_jetson.bin and flash again.
Hello @DavidDDD ,
I replaced uefi_jetson.bin with uefi_Jetson_DEBUG.bin
AGX_Orin_Flash_Error_2.log (121.5 KB)
Hello @DavidDDD ,
Any updates?
Sorry for the late response.
Based on your log, you dont flash successfully with the debug uefi.
With the debug uefi, it should show below logs like
Jetson UEFI firmware (version r36.4.3-85becaf8 built on 2025-03-12T09:37:15+00:00)
DRAM Encryption Enabled
Carveout 1 Region: Base: 0x0000000273000000, Size: 0x0000000000100000
Carveout 2 Region: Base: 0x000000027D000000, Size: 0x0000000000800000
Carveout 3 Region: Base: 0x0000000274800000, Size: 0x0000000000800000
Carveout 5 Region: Base: 0x0000000272F00000, Size: 0x0000000000100000
Carveout 6 Region: Base: 0x0000000274000000, Size: 0x0000000000800000
Carveout 7 Region: Base: 0x000000027D800000, Size: 0x0000000000400000
Carveout 8 Region: Base: 0x0000000272E00000, Size: 0x0000000000100000
Carveout 9 Region: Base: 0x0000000272D00000, Size: 0x0000000000100000
Carveout 11 Region: Base: 0x000000004007A000, Size: 0x0000000000002000
Carveout 12 Region: Base: 0x0000000272C00000, Size: 0x0000000000100000
Carveout 13 Region: Base: 0x000000004007C000, Size: 0x0000000000002000
Carveout 14 Region: Base: 0x000000004007E000, Size: 0x0000000000002000
Carveout 15 Region: Base: 0x0000000272B00000, Size: 0x0000000000100000
Carveout 16 Region: Base: 0x0000000040078000, Size: 0x0000000000002000
Carveout 17 Region: Base: 0x0000000272A00000, Size: 0x0000000000100000
Carveout 18 Region: Base: 0x0000000040076000, Size: 0x0000000000002000
Carveout 19 Region: Base: 0x0000000273180000, Size: 0x0000000000280000
Carveout 20 Region: Base: 0x000000027A000000, Size: 0x0000000002000000
Carveout 21 Region: Base: 0x0000000040074000, Size: 0x0000000000002000
Carveout 22 Region: Base: 0x000000027C000000, Size: 0x0000000001000000
Carveout 23 Region: Base: 0x000000027DC00000, Size: 0x0000000000200000
Carveout 24 Region: Base: 0x0000000278000000, Size: 0x0000000002000000
Carveout 25 Region: Base: 0x0000000040072000, Size: 0x0000000000002000
Carveout 27 Region: Base: 0x0000000272900000, Size: 0x0000000000100000
Carveout 28 Region: Base: 0x0000000276000000, Size: 0x0000000002000000
Carveout 30 Region: Base: 0x0000000040000000, Size: 0x0000000000040000
Carveout 33 Region: Base: 0x0000000273400000, Size: 0x0000000000400000
Carveout 34 Region: Base: 0x00000002727F0000, Size: 0x0000000000010000
Carveout 35 Region: Base: 0x0000000275000000, Size: 0x0000000001000000
Carveout 38 Region: Base: 0x0000000080000000, Size: 0x00000001F25F0000
Carveout 39 Region: Base: 0x000000027DE00000, Size: 0x0000000002200000
Carveout 40 Region: Base: 0x0000000040070000, Size: 0x0000000000002000
Carveout 42 Region: Base: 0x0000000272800000, Size: 0x0000000000100000
Carveout 43 Region: Base: 0x00000000BE000000, Size: 0x0000000004000000
Carveout 47 Region: Base: 0x0000000272000000, Size: 0x0000000000400000
Carveout 48 Region: Base: 0x00000002725D0000, Size: 0x0000000000020000
Carveout 49 Region: Base: 0x00000002725A0000, Size: 0x0000000000010000
Carveout 50 Region: Base: 0x0000000271E00000, Size: 0x0000000000200000
Carveout 54 Region: Base: 0x0000000273100000, Size: 0x0000000000080000
Carveout 55 Region: Base: 0x0000000040060000, Size: 0x0000000000010000
Carveout 56 Region: Base: 0x0000000273800000, Size: 0x0000000000800000
Carveout 61 Region: Base: 0x0000000040000000, Size: 0x0000000000050000
Carveout 62 Region: Base: 0x0000000040060000, Size: 0x0000000000010000
Carveout 63 Region: Base: 0x0000000040070000, Size: 0x0000000000010000
Carveout 69 Region: Base: 0x00000002725B0000, Size: 0x0000000000020000
Carveout 72 Region: Base: 0x00000002725F0000, Size: 0x0000000000200000
Processing "L4T Configuration Settings" DTB overlay
Processing "Tegra234 Carveouts Overlay" DTB overlay
Processing "OP-TEE overlay" DTB overlay
Processing "Tegra234 p3768-0000+p3767-xxxx Dynamic Overlay" DTB overlay
DTB maximums: sockets=1 clusters=3 cores=12
SocketMask=0x1 NumberOfEnabledCores=6
Model: NVIDIA Jetson Orin Nano Developer Kit
please reconfirm your debug uefi replace correct path.
Hello @DavidDDD ,
I noticed that the problem seemed to be caused by Type-C, because my customized board not use “cypress,cypd4226”.
So I modified #compatible = “cypress,cypd4226”; in tegra234-p3737-0000+p3701-0000.dts, and then I could Flash successfully.
Not sure if this approach follows the correct logic?
Yes, that’s the USB configuration related problem, and be sure all USB function can work well. Thanks
