I followed the tutorial here, conducted 3D Frequency Scaling,
and adjusted the frequencies of the CPU, GPU, and EMC. However, I found that after lowering the frequency of EMC, I cannot immediately set it to a higher value again. Why is that? Are there any hardware limitations?
For Example,
Firstly,
echo 204000 > /sys/kernel/debug/bpmp/debug/clk/emc/rate
Then, run cuda-sample
Then, run
echo 3199000 > /sys/kernel/debug/bpmp/debug/clk/emc/rate
