AGX Orin Fan PWM pull down resistor in Design Guide
Hello, I am designing a carrier board for an AGX Orin module. On the fan section, I noticed that the FAN_PWM signal is an open-drain per the design guide. However, the pin is pulled down via a 100k Ohm resistor, which will not do anything.
The reference design also have a pull down resistor too.
Is it a mistake on the design guide or is it something that I might have missed
Hi, the 100k is to set a stable pin status when no output. This pin is not used as OD function. It is used as SFIO in pinmux as PWM output.
