What is the extend of damage if DP1_HPD pin is pulled-up to 3.3V by a 10k resistor? I checked the resistance is 10M while new module (or the module used on 1.8V pull-up) is 24M. Looks like a 10M leakage is not a huge damage, however I am not sure on the long run. On the pinmux, there is an option to enable 3.3V tolerant, but the datasheet/design guide mentioned this pin is a 1.8V CMOS (no mention of being 3.3V tolerant). Does this 10M means this pin is actually protected against 3.3V input?
sgursal
3
If 3V3 tolerance is not enabled in the pinmux it will damage the pin on Orin. Please refer to Q17 in Jetson AGX Orin HW FAQ - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
Related topics
| 3.3V Tolerance Enable | 3 | 1145 | June 22, 2022 | |
| Using Orin NX PP.06 GPIO as 3.3V output with external pullup | 4 | 285 | March 25, 2025 | |
| About DP1_HPD(HP_DET) of the Jetson Orin NX | 2 | 699 | February 9, 2023 | |
| Pinmux template v1.1: cannot disable 3.3V tolerance after setting pin to Unused (cells protected) | 4 | 96 | March 3, 2026 | |
| Orin NX 8GB PP.06 GPIO | 7 | 389 | October 28, 2024 | |
| Pinmux configuration to change the logic level to 3.3 volts | 5 | 242 | February 20, 2025 | |
| Orin IO pin voltges | 1 | 568 | March 16, 2023 | |
| Invalid configuration output pin in custom development board | 3 | 118 | May 29, 2025 | |
| Can I set the io-high-voltage to disable by setting the register? | 4 | 155 | December 10, 2024 | |
| AGX Orin Internal Pull-Up Value | 3 | 71 | May 5, 2026 |
