What is the range of the Orin power-key pull-up resistance?
1689132241036
What is the range of the Orin(240PIN) power-key pull-up resistance?
Hi, please just keep same value with reference since that has been validated.
If it has to be modified, can you give a range? And what is the principle of resistance by choice? Thanks!
Please share why you “have to” change it? As said, others may be OK in theory but are not validated, so please simply use 10k for it.
By default, when Orin is not turned on, the PWR-KEY of other modules will be L due to the 10K partial voltage, so we want to increase it.
I don’t understand your use case. Anyway, you can try other options, but as said that are not validated.
