Orin NX Pin voltage level - documentation is not clear
Hi Orin NX experts!
Designing an Orin NX custom carrier board and have a couple of questions regarding the IO voltage levels of several pins.
In the Orin NX design guide it states that pin #240 SLEEP/WAKE* is a 5V CMOS input, but in the pin description the document states that the pin is pulled up by a 100k pullup resistor to 1.8V.
Pin #239 SYS_RESET* is stated as an 1.8V bidirectional pin, but in the description it states that this pin is pulled up by a 1kOhm resistor to 3.3V.
What are the correct voltage level for each of these pins?
Please help me figure this out…
Best regards!
The wake module pin is 5V, it goes to a 1.8V SoC pin through a diode.
SYS_RESET* is pulled up to 1.8V with 1K as OD pin, it is a typo in doc that will be corrected.
