ORIN NX /Orin Nano input power tolerance
We are designing a custom carrier board that adapts Orin Nano and Orin NX as well , So we decided to give 5V as input supply to the SOM .
But in the datasheet / design guide , It is simply given as the typical voltage of 5V for Orin Nano and 5V to 20V for Orin NX for Input voltage (Please refer the attached images), There is no Minimum or Maximum range like 4.75V to 5.25V.
What is the Minimum and Maximum acceptable Input voltage for Orin Nano and Orin NX ?
You should be able to get that in module data sheet like below.
