Maximum Voltage and Current
Hi, what is the max voltage and current for jetson orin nano? I’m thinking to use switching voltage regulator (12V, 5A) for it. The application is 3D scanner.
Do you mean jetson orin nano devkit?
Orin nano devkit DC_IN 7~19V, Max Current (A) 4.2A@19V.
Use 12V is OK, Jetson Power Estimator online tool to estimate the power of Orin NX and Orin Nano. It’s for module only, power with carrier still depend on what kind of peripherals attached on carrier.
Thanks you. That Online tool helps a lot.
