Wanna confirm if there is hardware watchdog in AGX Orin?
There is a pin which name is WDT_RESET_OUT_N(B54). However, I found KevinFFF said the B54 is not support yet, but the WDT should still work. Is the answer same as Jetpack 6.2? What’s the purpose of WDT_RESET_OUT_N?
Also, I found other article, Trumary said Orin module has own internal WDT. This is not the WDT_RESET_OUT_N, is it? And does this internal WDT work as hardware watchdog?
The final question is… if I’d like to enable the hardware watchdog, can I follow the article to implement the function?
My goal is simple: I would like to confirm whether the default internal watchdog in the Jetson Orin series (including AGX Orin, Orin NX, and Orin Nano) is a true hardware watchdog (e.g., integrated within the SoC/PMIC that can perform a full hard reset independently of the CPU/kernel state) rather than a software-based watchdog.
Could you please clarify this for the default internal WDT behavior across these Orin modules?
“We want to ensure system recovery via hardware reset in case of a full kernel freeze or crash.”
Not the SYS_RESET_N
I used this command to test the watchdog
sudo echo c > /proc/sysrq-trigger
The system will reboot automatically. But I’m not sure if this is hardware watchdog.
