zax
1
I have some pieces of AGX orin module
I have flashed the Jp5.0.2 from sdk manager with devkit
The flash logs show no error and devkit can boot normally
But when I open the Jetson Power GUI
I just saw 4 core cpu when the power mode is MAXN
And cat /proc/cpuinfo also show 4 cores only
I have tried the other pieces of AGX orin module
And they show 8 cores normally
kayccc
2
If I remember correctly, that seems to be an issue at old SW.
Please try with the latest JetPack 5.1.2.
Yes, your software is too old.
zax
4
Hi ,
Flash Jp 5.1.2 is okay, it showed 8 cores
Do you mean Agx orin not support Jp5.0.2 any more?
But my other pieces AGX orin module with Jp 5.0.2 is normal
Is that relate to module version?
Is that due to PCN210100?
你可以把你這幾片Orin AGX module的eeprom全部dump出來給我們確認
You can try to dump all the module eeprom info to us to check.
sudo i2cdump -y 0 0x50
zax
6
Here’s one of 4 cores module eeprom info
please help to check
The others are in the factory
It may need some times to get the logs
eepromdump.txt (1.2 KB)
there was a agx-orin-a04-overlay-351.tbz2 overlay patch in this website. You may try to apply.
If this does not help fix the issue, I can only suggest you to upgrade BSP.
system
Closed
9
