I followed the steps in PCIe Endpoint Mode and get this message by running "lspci -v " in root port system.
p@p-desktop:~$ lspci -v
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 51
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: 00001000-00001fff [size=4K]
Memory behind bridge: 40000000-400fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities: <access denied>
Kernel driver in use: pcieport
0001:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
Subsystem: AzureWave RTL8822CE 802.11ac PCIe Wireless Network Adapter
Flags: bus master, fast devsel, latency 0, IRQ 310
I/O ports at 1000 [size=256]
Memory at 20a8000000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: rtl88x2ce
Kernel modules: rtl8822ce
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 55
I/O behind bridge: [disabled]
Prefetchable memory behind bridge: 0000002740000000-00000027400fffff [size=1M]
0005:01:00.0 RAM memory: NVIDIA Corporation Device 0001
Flags: fast devsel, IRQ 255
Memory at 2b28000000 (32-bit, non-prefetchable) [disabled] [size=64K]
Memory at 2740000000 (64-bit, prefetchable) [disabled] [size=128K]
Memory at 2b28010000 (64-bit, non-prefetchable) [disabled] [size=4K]
p@p-desktop:~$
Is this correct or something that I missed?
Thx
Yen
