Interfacing AGX Orin endpoint to an x86 PC using SRNS clocking
Hi everyone,
We are facing an issue trying to enable PCIe Endpoint functionality on the AGX Orin DevKit (C5) using a internal non-spread spectrum clock (external clock disabled) based on PCIe endpoint clocking recommendation from the design guide.
The AGX Orin DevKit is connected to the x86 Host PC through a cable. The x86 PCIe clock has the spread spectrum disabled in the BIOS.
Here’s what I’ve done:
  1. Modified the BPMP file (tegra234-bpmp-3701-0000-3737-0000.dtb) to enable the internal clock (NVHS UPHY) and disable spread-spectrum.
  2. Modified the device tree (kernel_tegra234-p3701-0000-p3737-0000.dtb) to disable the external clock (“nvidia,enable-ext-refclk” removed) and enable SRNS (“nvidia,enable-srns” added).
  3. Followed the instructions in the NVIDIA documentation to enable PCIe Endpoint Mode: PCIe Endpoint Mode — Jetson Linux Developer Guide documentation
However, after starting the PCIe EP on the DevKit and powering on the PC, we are getting continuous error output and a crash.
root@jetson:/sys/kernel/config/pci_ep# cd /sys/kernel/config/pci_ep/
root@jetson:/sys/kernel/config/pci_ep# mkdir functions/pci_epf_nv_test/func1
root@jetson:/sys/kernel/config/pci_ep# echo 0x10de > functions/pci_epf_nv_test/func1/vendorid
root@jetson:/sys/kernel/config/pci_ep# echo 0x0001 > functions/pci_epf_nv_test/func1/deviceid
root@jetson:/sys/kernel/config/pci_ep# ln -s functions/pci_epf_nv_test/func1 controllers/141a0000.pcie_ep/
root@jetson:/sys/kernel/config/pci_ep# echo 1 > controllers/141a0000.pcie_ep/start
root@jetson:/sys/kernel/config/pci_ep# sudo dmesg | tail
[   18.443574] Adding 3501880k swap on /dev/zram7.  Priority:5 extents:1 across:3501880k SS
[   18.863172] fuse: init (API version 7.32)
[   18.918783] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  35.5.0  Release Build  (buildbrain@mobile-u64-6519-d7000)  Mon Feb 19 20:34:14 PST 2024
[   19.007558] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[   19.172997] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   36.314615] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[   46.606975] pci_epf_nv_test pci_epf_nv_test.0: BAR0 RAM phys: 0x131dfa000
[   46.606993] pci_epf_nv_test pci_epf_nv_test.0: BAR0 RAM IOVA: 0xffff0000
[   46.607025] pci_epf_nv_test pci_epf_nv_test.0: BAR0 RAM virt: 0x0000000061ebd90c
------------------------POWER ON PCIe Root Complex-----------------------------------------
root@jetson:/sys/kernel/config/pci_ep# [   53.268971] CPU:0, Error: cbb-fabric@0x13a00000, irq=22
[   53.269136] **************************************
[   53.269281] CPU:0, Error:cbb-fabric, Errmon:2
[   53.269411]    Error Code            : TIMEOUT_ERR
[   53.269524]    Overflow              : Multiple TIMEOUT_ERR
[   53.269667]
[   53.269721]    Error Code            : TIMEOUT_ERR
[   53.269832]    MASTER_ID             : CCPLEX
[   53.269931]    Address               : 0x3e90078
[   53.270037]    Cache                 : 0x1 -- Bufferable
[   53.270154]    Protection            : 0x2 -- Unprivileged, Non-Secure, Data Access
[   53.270348]    Access_Type           : Read
[   53.270454]    Access_ID             : 0x17
[   53.270455]    Fabric                : cbb-fabric
[   53.270653]    Slave_Id              : 0x2e
[   53.270734]    Burst_length          : 0x0
[   53.270820]    Burst_type            : 0x1
[   53.270916]    Beat_size             : 0x2
[   53.271005]    VQC                   : 0x0
[   53.271147]    GRPSEC                : 0x7e
[   53.271618]    FALCONSEC             : 0x0
[   53.272079]    AXI2APB_28_BLOCK_TMO_STATUS : 0x2
[   53.272772]    AXI2APB_28_BLOCK1_TMO : 0x10000
[   53.273432]  **************************************
[   53.274196] WARNING: CPU: 0 PID: 197 at drivers/soc/tegra/cbb/tegra234-cbb.c:578 tegra234_cbb_isr+0x130/0x170
[   53.280143] ---[ end trace 8dc5ff7311a56a17 ]---
[   53.284698] CPU:0, Error: cbb-fabric@0x13a00000, irq=22
[   53.289912] **************************************
[   53.294898] CPU:0, Error:cbb-fabric, Errmon:2
[   53.299190]    Error Code            : TIMEOUT_ERR
[   53.302948]    Overflow              : Multiple TIMEOUT_ERR
[   53.307678]
[   53.309248]    Error Code            : TIMEOUT_ERR
[   53.313009]    MASTER_ID             : CCPLEX
[   53.316247]    Address               : 0x3e900c0
[   53.319747]    Cache                 : 0x1 -- Bufferable
[   53.323949]    Protection            : 0x2 -- Unprivileged, Non-Secure, Data Access
[   53.330686]    Access_Type           : Write
[   53.334361]    Access_ID             : 0x0
[   53.334362]    Fabric                : cbb-fabric
[   53.341097]    Slave_Id              : 0x2e
[   53.344247]    Burst_length          : 0x0
[   53.347660]    Burst_type            : 0x1
[   53.350984]    Beat_size             : 0x2
[   53.354134]    VQC                   : 0x0
[   53.357022]    GRPSEC                : 0x7e
[   53.360172]    FALCONSEC             : 0x0
[   53.363149]    AXI2APB_28_BLOCK_TMO_STATUS : 0x2
[   53.367787]    AXI2APB_28_BLOCK1_TMO : 0x10000
[   53.372249]  **************************************
[   53.376988] WARNING: CPU: 0 PID: 197 at drivers/soc/tegra/cbb/tegra234-cbb.c:578 tegra234_cbb_isr+0x130/0x170
[   53.386912] ---[ end trace 8dc5ff7311a56a18 ]---
Note, that endpoint functionality works as expected with the PCIe common clock configuration (when “nvidia,enable-ext-refclk” is set in the device tree) and the PC is able to properly enumerate and initialize the endpoint BARs.
Am I missing any steps to correctly enable PCIe endpoint function with a separate non-spread spectrum clock? Any help or suggestions would be greatly appreciated!
Both BPMB and kernel device tree files are provided for review.
kernel_tegra234-p3701-0000-p3737-0000.dtb.txt (429.1 KB)
tegra234-bpmp-3701-0000-3737-0000.dtb.txt (246.1 KB)
Yes, some steps are missing.
kernel dts
  1. Add “nvidia,enable-srns” property in PCIe RP/EP node.
  2. Delete “nvidia,enable-ext-refclk” property in PCIe RP/EP node to support SRNS with internally generated clock.
bpmp dts
pcie-c5-endpoint-use-int-refclk; → this one is missing.
Disable Spread Spectrum Control (SSC). → looks like already added.
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html?highlight=srns#enabling-srns-for-pcie-endpoint
