现有一个AGX Orin和一个RTX 3060显卡,版本如下:
user@user-desktop:~$ head -n 1 /etc/nv_tegra_release
R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
Linux user-desktop 5.15.136-tegra #5 SMP PREEMPT Thu May 16 11:05:28 CST 2024 aarch64 aarch64 aarch64 GNU/Linux
显卡安装后,通过nvidia-smi无法看到3060显卡
安装NVIDIA-Linux-aarch64-550.90.07.run 显卡驱动会造成图形界面丢失,只能通过字符界面登录
kayccc
3
No, Jetson device can’t support external GPU card.
谢谢你的回答,麻烦再问下
1、在未来是否会支持外部GPU卡?
2、AGX Orin PCIE插槽一般适用于拓展什么类型的设备?
谢谢你的回答,麻烦再问一下:
1,未来Orin是否会有支持外接GPU卡的计划?
2,Orin的PCI插槽一般适用于外接什么设备?
kayccc
6
No, there is no plan.
You may refer to those project sharing at Latest Jetson & Embedded Systems/Jetson Projects topics - NVIDIA Developer Forums to know what they used or depends on your use case.
好的 谢谢
再确认一下 Jetson 设备不支持外部GPU卡 包括所有Nvidia所有系列的GPU卡吗? 譬如:
GeForce、Quadro、Tesla等
kayccc
8
We have IGX which can support Tesla A600 card, you can find more information from NVIDIA IGX Orin - NVIDIA Docs
system
Closed
9
