I was following the AGX Orin pinout assignments and get: GPIO17 → pin ‘22’, GPIO27 → pin ‘15’, GPIO35 → pin ‘18’,
I was able to enable these 3 GPIOs using those pin numbers: 22, 15, and 18, and they work perfectly fine. However, I need to use GPIO11 as well, and I am not able to find the pin number for GPIO11. Could you please help!
You should ask the vendor for help, as this is a custom carrier board, and we don’t have the same device.
Anyway, aren’t they already shown here?
I don’t really know what you cannot get.
Thank for the response!
I have asked the vendor, and they gave me the same manual that you have.
I don’t know how to enable GPIO11 when it shows “GPIO_2 (GPIO11 / PAC.05 491)”. How would you enable it in Python code? Or what did you mean by it’s already shown here?
For other GPIOs, in my code, I did like:
For GPIO17: output_pin1 = 22
For GPIO27: output_pin4 = 15
For GPIO35: output_pin5 = 18
Now, how do I do it for GPIO11: output_pin2 = ??
I’m looking for the number ??
I don’t even know what Python code you are running.
Maybe there’s some setting in the library allowing you to change the method of how a pin is numbered.
The expansion header of this AID-KX13 is also completely different from that on a DevKit.
We cannot help on this.
