Continuing the discussion from Problem in Xavier NX Synchronized Capture:
Now my hardware platform has been changed to AGX orin, and the software system jp5.1.1 (l4t35.3.1),has also been modified the sample Argus/sample/syncSensor,The system library only supports up to 4 cameras,all output files having the same image from camera 0
The code I modified: main.cpp (16.9 KB)
6 cameras can not be support,has reported an error during program execution:
I was checking this internally.
only 1 stereo pair (i.e. left/right to be in sync) is verified; we’ve not tested more than 2-cam for synchronized capture now.
My application requires multiple sensor synchronized captures. I previously communicated with NVIDIA that they will be supported in the new package. Please confirm if there is a solution that can be implemented?
