Jetson AGX Orin -- 1080P 10FPS
Hi Team
I want to know how many cameras(2MP – IP Cameras) can be connected to AGX Orin dev kit and if I want to stream them in 1080P at 10FPS.
Kindly give the same information for Jetson Orin NX too.
There’s no problem to support it.
Hi @ShaneCCC
In the datasheet it is given that 12 cameras can be connected to AGX Orin 32GB if the the video resolution is 1080p at 30fps, but I want to use 1080p at 10fps feed for the Jetson AGX Orin. In this, can i increase the number of cameras feed to jetson AGX Orin or will it remain same as 12.
I just want to know regarding number of cameras that can be mounted to Jetson AGX Orin if the streaming is happening at 1080p 10fps.
The frame rate and resolution doesn’t matter with that.
Orin support up to 6 cameras
(16 via virtual channels**)
16 lanes MIPI CSI-2
Hi @ShaneCCC
In my case, it is IP camera. Can we use more cameras by using external switch? if yes how many cameras can be used.
Jetson Orin 32gb encodes 12 streams if they are in 1080p at 30fps, what does this statement mean?
What’s the interface of the IP cam?
If it USB3 camera current only verify three, don’t know if able support more than 3 or not in current release.
