I want to connect two LWIR cameras to the AGX Orin, but I want to use the Ethernet interfaces on the device (1 GB and 10 GB).
My question is very similar to this topic:
Jetson Orin - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
That topic is closed, but I want to get more information about this.
To confirm, is it possible to connect two cameras to the Ethernet ports of the Orin, as stated in the topic above? Apart from configuring gstreamer with the command given, what else might be necessary? Is there anything else I should keep in mind?
