Jetson Orin
I need to interface two LWIR cameras to the Jetson Orin. The camera outputs its video data via a 1 GB Ethernet port. I see the Orin has a 1 GB and 1 10 GB ethernet port. Can I interface my cameras to these ethernet ports for video processing?
Is the camera similar to IP cameras? A general use-case is to connect to IP cameras through Ethernet and the source is H264/H265 stream. Jetson device has hardware decoder to decode the stream to get YUV420 frame data.
Thanks, for the response. Yes, the cameras are IP protocol.
It should be supported. You would need to change network setting to enable the IP cameras with IP address assigned. And then run the gstreamer command like:
$ gst-launch-1.0 rtspsrc ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw ! xvimagesink sync=0
