AGX Orin UART2 data lost when loopback test
Hi Nvidia,
We used UART2_RX(C56) / UART2_TX(C58) in our custmor carrier board.
AGX Orin 32GB, JetPack 6.2
The usrt data will lost in loopback test. The TX/RX pin are level-shifted from 1.8 V to 3V.
~$ sudo stty -F /dev/ttyTHS3 115200 -crtscts raw -echo
~$ sudo cat /dev/ttyTHS3 &
[1] 10784
~$ sudo sh -c "echo 'UART2-LOOP-TEST123456789AB' > /dev/ttyTHS3"
~$ AB
~$ sudo sh -c "echo 'UART2-LOOP-TEST123456789ABCDEF' > /dev/ttyTHS3"
~$ ABCDEF
~$ sudo sh -c "echo 'TEST123456789' > /dev/ttyTHS3"
~$ 56789
This is my dts and pinmux
                        uart5_tx_py5 {
                                nvidia,pins = "uart5_tx_py5";
                                nvidia,function = "uarte";
                                nvidia,pull = <TEGRA_PIN_PULL_NONE>;
                                nvidia,tristate = <TEGRA_PIN_DISABLE>;
                                nvidia,enable-input = <TEGRA_PIN_DISABLE>;
                                nvidia,lpdr = <TEGRA_PIN_DISABLE>;
                        uart5_rx_py6 {
                                nvidia,pins = "uart5_rx_py6";
                                nvidia,tristate = <TEGRA_PIN_ENABLE>;
                                nvidia,enable-input = <TEGRA_PIN_ENABLE>;
uart2.dts.txt (319.4 KB)
Hi Wilson_Lin,
Have you confirmed that you’ve shorted UART2_TX and UART2_RX correctly?
Please share the full dmesg for further check.
You can also check if the following commands can help for your case.
$ sudo systemctl stop nvgetty.service
$ sudo systemctl disable nvgetty.service
$ sudo systemctl status nvgetty.service
Hi Kevin,
Yes I shorted UART2_TX and UART2_RX. If not, I can’t get any respones.
~$ sudo systemctl status nvgetty.service
○ nvgetty.service - UART on ttyTHS0
     Loaded: loaded (/etc/systemd/system/nvgetty.service; disabled; vendor preset: enabled)
     Active: inactive (dead)
I disable the nvgetty but still lost the data.
This is my dmesg.
uart2_dmesg.log (65.3 KB)
Have any update?
[    1.862000] 3140000.serial: ttyTHS3 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
This is the UART2 you are using.
Could you try removing the following line in the device tree to see if that helps>
		serial@3140000 {
			compatible = "nvidia,tegra194-hsuart";
			reg = <0x00 0x3140000 0x00 0x10000>;
			interrupts = <0x00 0x74 0x04>;
			clocks = <0x03 0x9f>;
			resets = <0x03 0x68>;
-			dmas = <0xee 0x14 0xee 0x14>;
-			dma-names = "rx\0tx";
			status = "okay";
			reset-names = "serial";
			phandle = <0x22f>;
Hi Kevin,
Thank a lot.
The echo loopback test is OK.
Does turning off DMA reduce UART performance?
I think using UART in PIO mode would be fine for your use case as you are using 115200 as baud rate.
Thanks a lot again.
