AGX ORIN usb3.0 does not work or is recognized as 2.0 on USB1
hi, nvidia teams
We use a Jetson AGX ORIN(64GB) with custom board L4T 35.5.0(Jetpack 5.1.3).
We are using USB1 as Type A(not Type C), so PD controller doesn’t exist.
Our problems are as follows.
If I connected the usb 3.0 drive directly to the board, I got an error as shown in the figure below.
If I connected the usb 3.0 drive through usb 3.0 hub multi-port, it will be connected, but it will be recognized as 2.0(Device 10 usb-storage).
upload our dmesg log and dts file.
dmesg.log (68.4 KB)
dts.zip (2.3 KB)
Are there any more logs or files I need to share?
Thank you.
Please make sure you configure host-only mode in device tree for the type-A port, and do compliance test to confirm signal quality is good:
Jetson Download Center | NVIDIA Developer
thank you, I’ll try compliance test
Resolved. The reason is that superspeed RX and TX are swapped.
