AGX Thor JPEG HW decode
I read from Jetson Linux API Reference: 00_video_decode (video decode) | NVIDIA Docs that the gst plugin nvv4l2decoder on Thor does not support JPEG/MJPEG decoding. Is there any other suggested way to do hardware decoding of JPEG? Does nvJPEG work?
Please try the sample for JPEG decoding:
/usr/src/jetson_multimedia_api/samples/06_jpeg_decode
Hello @etaripek
The decoder you need is nvjpegdec instead of nvv4l2decoder. You can check the plugin capabilities and properties.
If you execute `gst-inspect-1.0 nvjpegdec` you can see:
  mjpegdecode         : Enable mjpeg decoder path for decode operations
                        flags: readable, writable, changeable only in NULL or READY state
                        Boolean. Default: true
Please let me know if this works for you!
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
