Software Version
Jetpack4.6.1
Target Operating System
Linux
Hardware Platform
AGX Xavier- customized board
SDK Manager Version
L4T-32.7.1
Host Machine Version
Ubuntu 18.04
The board can boot up nomally, it just can’t be flash.
when I run flsah.sh, the program was blocked in ‘tegrarcm_v2 --isapplet’.
I found a similar topic, and follwing the solution, I checked Strapping Pins as OEM Develop Guide, but found nothing wrong.
Is there any problem ignored?
The flash log prints following below:
[ 0.1475 ] Signing RCM messages
[ 0.1501 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1503 ] Assuming zero filled SBK key
[ 0.1636 ] Copying signature to RCM mesages
[ 0.1663 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1684 ]
[ 0.1685 ] Boot Rom communication
[ 0.1711 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1723 ] RCM version 0X190001
[ 0.1981 ] Boot Rom communication completed
[ 1.2143 ]
[ 2.2195 ] tegrarcm_v2 --isapplet
[ 2.2217 ] Applet version 01.00.0000
[ 2.2963 ]
[ 2.3002 ] tegrarcm_v2 --ismb2
[ 2.3923 ]
[ 2.3963 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.3987 ]
[ 2.4025 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.4046 ] adding BCH for nvtboot_applet_t194.bin
[ 2.4094 ]
[ 2.4122 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.4124 ] Assuming zero filled SBK key
[ 2.4224 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.4281 ]
[ 2.4314 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.4331 ] Applet version 01.00.0000
[ 2.5079 ] Sending mb2
[ 2.5081 ] [................................................] 100%
[ 2.5238 ]
[ 2.5276 ] tegrarcm_v2 --boot recovery
[ 2.5297 ] Applet version 01.00.0000
[ 2.6078 ]
[ 3.6130 ] tegrarcm_v2 --isapplet
Additionally,when flash.sh runs, the uart log prints as follow:
[0023.133] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0023.141] I> MB1 (prd-version: 1.5.1.9-t194-41334769-73a9b7ef)
[0023.147] I> Boot-mode: Platform RCM
[0023.150] I> Chip revision : A02P
[0023.153] I> Bootrom patch version : 15 (correctly patched)
[0023.158] I> ATE fuse revision : 0x200
[0023.162] I> Ram repair fuse : 0x0
[0023.165] I> Ram Code : 0x2
[0023.167] I> rst_source : 0x0
[0023.170] I> rst_level : 0x0
[0023.174] I> USB configuration success
[0025.443] I> mb2 image downloaded
[0025.527] I> Recovery boot mode 0
[0025.530] E> Unsupported boot-device strap-reg: 0x00000004
[0025.535] E> Get boot dev failed
[0025.538] E> UPHY lane_config get failed
[0025.542] E> Task 44 failed (err: 0x1e1e0001)
[0025.546] E> Top caller module: SOCMISC, error module: SOCMISC, reason: 0x01, aux_info: 0x00
[0025.554] I> MB1(1.5.1.9-t194-41334769-73a9b7ef) BIT boot status dump :
0000000000011111111111100000000000000000000010000000000000000000000000000000000000000000000000000000000000000000000000000000000011001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0025.584] I> Reset to recovery mode
