Hi
now i want to use the GPIO23(GPIO(Z, 2)) as USB3-0(UPHY6) 's PD Control binding GPIO
how can i modify to make the binding gpio of usb3-0 to be GPIO23 and make it worked?
By the way ,i use the AGX Xavier, version =# R32 (release), REVISION: 5.1, GCID: 26202423, BOARD: t186ref, EABI: aarch64, DATE: Fri Feb 19 16:50:29 UTC 2021
Thank you very much.
Please refer to the adaptation guide.
Hi WayneWWW
I have read the guide. But i still have a question.
How can i bind the gpio to be vbus? in where dts?
Thank you
Are you talking about the vbus for usb otg mode state table or you are talking about the vbus-supply ?
Hi
vbus-supply
now i use the gpio USB_CH2_PRT_CTL to be the vbus. how can i bind the gpio to be the usb vbus. (the usb link UPHY6)
1- \hardware\nvidia\platform\t19x\galen\kernel-dts\common\tegra194-fixed-regulator-p2822-1000.dtsi
p2822_vdd_5v_sata: regulator@114 {
compatible = "regulator-fixed";
reg = <114>;
regulator-name = "vdd-5v-sata";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Z, 1) 0>;
enable-active-high;
vin-supply = <&battery_reg>;
p2822_vdd_5v_sata2: regulator@115 {
reg = <115>;
gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(Z, 2) 0>;
enable-active-high;
2 - i verify the tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
pinmux.0x02430060 = 0x00000459; # soc_gpio22_pq2: nv, pull-up, tristate-enable, input-enable, lpdr-disable
pinmux.0x02430068 = 0x00000414; # soc_gpio23_pq3: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
verify like below
pinmux.0x02430068 = 0x00000459; # soc_gpio23_pq3: rsvd0, pull-down, tristate-enable, input-disable, lpdr-disable
3 - cat the gpio status
mount -t debugfs debugfs /test
cat /test/gpio
And the status is below:
gpio-489 ( |vdd-5v-sata ) out hi
gpio-490 ( |vdd-5v-sata ) out lo
the gpio-490 is still output low
please help
i don’t find the code where make the relationship about the gpio and vbus
Thank you
HI,
Did you assign this regulator to the “vbus-supply” property under the usb2-x port?
Something like
usb2-0 {
vbus-supply = <__you_need_to_assign_the_regulator_here>;
Hi
it’s my code, i think i am wrong here. how can i verify?
ports {
usb2-1 {
mode = "host";
vbus-supply = <&battery_reg>; //zp
status = "okay";
Have any blog or case can be read?
Since you already modify “p2822_vdd_5v_sata” regulator to match your hardware (with GPIO Z,1), then you can just tell usb2-0 to use p2822_vdd_5v_sata instead of battery_reg as regulator, if your usb2-0 port is using GPIO Z,1.
battery_reg is a dummy regulator we set by default.
thanks WayneWWW
now it worked.
