AGX XAVIER Industrial can't flash image
Our customer use AGX XAVIER Industrial Module. Software development and production version is JetPack 4.6.1 (L4T 32.7.1).
Recently, the new modules used by the factory cann’t flash the image. We traced the PCN record and found that PCN209842 changed BOM Components: Micron DRAM. These modules can be normally flash the image after jetpack4.6.4 (L4T 32.7.4) version.
The customer’s project has been mass produced and applied in the vehicle , We would like to request a new DRAM patch file based on JetPack 4.6.1(L4T 32.7.1) form PCN209842 .
32.7.1 flash error log.txt (49.6 KB)
Hi Zengwj,
Are they on the devkit or custom board for AGX Xavier?
Have you considered using image-based OTA to the latest Jetpack 4.6.5 (R32.7.5)?
[   7.4228 ] 0000000000000102: E> NONE: Invalid value MemBct dram size: 0MB for slot: 3.
[   7.4394 ]
[   7.4394 ]
Error: Return value 2
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Failed flashing t186ref.
Yes, it seems the flash failed issue is relating to DRAM.
Please let me check if there’s available overlay PCN package with internal.
Hi KevinFFF:
We have completed the verification on AGX Xavier development KIT and the customer’s carrier board, then the problem is the same. Customer want to support memory patch to solve this problem , because OTA upgrade needs too many changes
Okay, sorry that we don’t support to provide PCN packages on forum.
Please contact your sales or local distributor or NVIDIA representative for the PCN package.
