AGX Xavier power button implementation with Automation header (J511)
Is it possible to implement a power on/off button by shorting certain pins on the J511 automation header?
If yes, which J511 pins should be connected on the AGX Xavier devkit?
Thx!
Hi, do you mean J511 (for audio) or J508 ? If J511, no such pin. If J508, pin 4 (BUTTON_POWER_ON) can be used by shorting to GND. You can check reference schematic for that.
My bad, not J511 but J508. Thx!
