Jetson AGX Xavier Auto power On
I have Jetson AGX Xavier Developer Kit
all i need
to make it powered ON Without touch it’s power button
. like when power source is connected to It, i want it automaticly to turned on.
"wake on lan " won’t help because it neet device to be in standby status.
Do you mean auto power on when you connect the power cable?
This requires hardware rework. Please check this section in xavier design guide.
As per the Notes on page 31 of the document: https://static5.arrow.com/pdfs/2018/12/12/12/23/1/848262/nvda_/manual/jetson_xavier_developer_kit_carrier_board_specification.pdf
pin 5 & 6 can be shorted for Auto-Power-On. [8-pin Header (J508) ]
Notes: - Auto-Power-On is enabled when pins 5 & 6 are tied together
thanks alot it works fine :)
