One of the NVIDIA Jetson AGX Xavier dev kit that I was playing around with now always powered on as soon as its connected to power adapter. It does not need the power button on the device to be pressed. Is this a Hardware issue/failure? Has someone come across this problem, Is there a fix for this issue?
I can confirm that there is no Jumper between pins 5 and 6 of J508. I did read this post about Boot on Power ON and was thinking if there is any way these pins could have been shorted due to hardware failure.
hello suraj.shetty,
are you using usb-c? may I know which port you’re used for the power-supply.
thanks
