Hi, do you mean the issue is on the carrier board not module? To locate issue, first you need to check the signals involved in power on sequence (listed in OEM DG), that might give hints on root cause.
Yes, it seems that the problem is the carrier board and not the module since swapping carrier boards allows the module to boot.
The power on sequence in the DG does show a few lines that need to be pulled high for module to boot but I can’t discern where to probe on that on the carrier board. I tried changing up the sequence by powering through usb-c and by changing the jumper to auto boot on power but neither worked.
I haven’t been able to figure out what’s wrong with the Jetson. How do I send it in for warranty support? The NVIDIA chat rep said to make a post on this forum.
